many cranks to start
Discussion in 'The Garage' started by mtrdrms, Mar 29, 2005.
  1. mtrdrms
    mtrdrms 1/2 ton status
    Mar 14, 2005
    312
    Torrington, CT
    I have an 87 350 FI. I just had the motor rebuilt but that didnt affect my problem. Whether it is hot or cold the truck takes like 2 seconds of cranking to finally start running on its own. Its a little embarrasing and I cant seem to make it go away. Any suggestions? Other than that the motor is tip-top.
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    2 seconds isnt that long lol. Is it cranking over at a good speed? Is it sluggish turning over, like a weak batt, or batt cables? Also, is the fuel system pressurizing when u switch the key to on, b4 you turn it to start?
  3. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    That's just how TBI motors work.
  4. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Maybe timming? How about the air idle sensor, its like the choke but takes a few seconds to read and set for cranking. :xmas:
  5. dyeager535
    26,982
    191
    I'm with you on the fuel pressure.
    Do you hear the pump run when the key is turned to "run", before you start the engine?
  6. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    Don't the oil pressure sending units have something to do with start-up? I believe I heard that it won't let the engine fire until it senses enough oil pressure.
  7. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    on the tbi engines if the the fuel relay fails the fuel pump will not kick in until the oil pressure sensor reads 4 psi of pressure usually resulting in longer than normal cranking times
  8. dyeager535
    26,982
    191
    Yeah, as stated, if relay fails, oil pressure is what will "start" the fuel pump.
    Thus, if the pump doesn't prime when key is turned to run, the relay is suspect.
  9. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Yep, I believe we have a winner. :xmas: I'm voting fuel relay also.
  10. mtrdrms
    Mar 14, 2005
    312
    Torrington, CT
    The pump sounds like it is priming the system. I can hear it anyway. What is the fuel relay and how do I test it?
  11. 87XJCO
    87XJCO Newbie
    Mar 30, 2005
    DENVER, CO
    suggestion. turn the key to on for 2 seconds and then turn off. then crank engine nomally and see if it starts right up. This runs the fuel pump briefly and the injectors cycle once. Might eliminate some of you r possible causes.
