many leaks...
Discussion in 'The Garage' started by el guapo, Jan 11, 2004.
  1. el guapo
    el guapo Registered Member
    Dec 6, 2003
    7
    Front main seal leak, Rear main seal leak, Transmission pan gasket leak, Valve cover leak, Oil pan gasket leak, Head gasket leak, Transfer case leak, Front differential leak.
    that's the laundrey list.
    just finished doin my electric to manual choke conversion, and this is everything i've found.
    '86 K5 305ci
  2. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    Sounds like you need to do the old radiator cap trick /forums/images/graemlins/grin.gif.>>>>>Remove the radiator cap in an upward motion, and then pull another 86 K5 underneath. Then slowly lower radiator cap back down into position. /forums/images/graemlins/laugh.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I wouldn't even bother to fix the 305, just pull it. /forums/images/graemlins/thumb.gif
  4. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    a lot of that can be fixed with just replacing the gasaket, ive done my tranny quit a few times and knock on wood, that things always been bone dry. my oil pan leaks, cause its rotted, and my diffs leak when its really warm out if they dont seel right. does ur t-case leak out the output shaft there? i guess thats pretty commen, mine does to.
  5. Tshane
    Tshane 1/2 ton status
    Nov 26, 2002
    144
    Peoria, Illinois
    lol sounds like a chevy
  6. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Sounds like time to replace the FS gasket set! There is a company that offers the new style gaskets with no over torque sleeves in the gaskets! I see so many rigs that have had new gaskets over torqued and squish out and leak!
    Bill
  7. Tweetysuarus
    May 25, 2002
    2,294
    Lynnhood,WA
    Bill
