many questions
Discussion in 'The Garage' started by chris walker, Feb 15, 2007.
  1. chris walker
    chris walker Registered Member
    Sep 5, 2005
    42
    Arizona
    Question 1. which would give more bang for buck rebuilt 350 with new cam,intake, ingnition,carb
    all the aftermarket ones made for low end torque
    or a 454 with the same things its for a k5 blazer that will have between 35-37" tires and 4.10-4.56 gearing with a sm465
    Question 2. how wide is an eaton also how much do they weigh also would a 9.5" 14 bolt hold up to said tires and engines also how much does a 9.5 SF 14 bolt weigh
    Question 3. how bag would my gas mileage get if I whent full time four wheel drive with a 203 instead of a 205
  2. 01maroonz71
    01maroonz71 1/2 ton status
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    well, chris...there is no replacement for displacement as im sure you've heard before...so i say go with the 454 all the way, rebuilt as stated above....based on your tranny/gearing options...it sounds like this will be an offroad truck only, so your gonna wann go FF for sure, so plan on upgrading to 1ton running gear...even with just 35's or 37's you'll find the weak link fast with a big block and that low gearing(trans)
    the 205 is one of the wheeling holy grails IMO so going to most any other case would be a mistake, especially if it's for the same truck in the first two questions.
    oh yeah, 25bucks goes a long way on this site....
  3. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    296
    Truckee, CA
    1. The stock 454 would prolly make more torque than teh modded 350...if my guess on a mild build is what you are doing.
    2. 14bolt ff will laugh at those tires and gearing....no prob.
    3. I don't see ANYONE on here converting to full time. Why? if you got a 203, you woudl prolly want to get a part time kit for it. But why get a 203 if you have a 205? the 205 is the mother of all tcases around here. its a strong beast.
  4. Elevator Man
    Elevator Man 1/2 ton status
    Dec 23, 2005
    240
    Bigelow, Arkansas
    Why would you trade a 203 (chain drive) for a 205 (gear drive)????????????
  5. 01maroonz71
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    dhcomp, a 9.5 14bolt is a SF, not a FF...10.5inch ring gear is FF....no bueno.
  6. chris walker
    Sep 5, 2005
    42
    Arizona
    would the eaton hold up to the engine tires plus it will be a daily driver I dont really drive far to work like 3 miles so its not a big deal about gas miliage I was just wondering also the 203 seems to me to be a good case if you get the one with the 2.50" chain but I do agree on the 205 which is what I will probably get
    Im trying to figure out how I whant to build the k5 my first plan was this
    built 350 sm465 np203 Dodge front 9.25 retubed and a full flaoting 9.5" 14 bolt I know I would have to make it a full float
    the second plan is this 454 sm465 np205 from a ford and a eatong front I know I would have to make it and an eaton rear both would have the ho72 third members with detroits
  7. dhcomp
    Mar 17, 2001
    9,862
    296
    Truckee, CA
    I always forget the ring gear sizes, guess its good i said 14FF specifically :doah:
  8. 01maroonz71
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    yeah man...205 hands down...and go 14ff in the rear, and never look back...you may get away with a stock8lug front(3/4ton) dana44 or 10bolt, whatever you have...but that's with a 350, and a very very mild one...and a very very light amount of "go pedal" haha...good luck with the build.
