March power steering bracket dont work
Discussion in 'The Garage' started by trailblazr81, Aug 7, 2005.
  1. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    So I just bolted my new March power steering bracket to my engine. I tried to bolt it to the pump but its not working. The front lower bracket is hiting part of the reservoir. My pump reservoir bulges out right obove where the bracket is to bolt on. So I cant pull the pump in enough to bolt on the top mount. Anyone else have his problem? :dunno:
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've yet to hear of a March product that fits properly. :mad:
  3. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    i bought a March PS kit for my 454 w/long water pump, fit like a champ.
  4. XCUATRO
    XCUATRO Registered Member
    Jul 4, 2002
    31
    so. cal.
    Do you have the correct march Kit? :confused: They make one for 1966-1976 and one for 1978- with metric threads. Check out www.marchperf.com Hope this helps.
  5. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Yes I have the right one. I was finally able to get all the bolts in, but to do so I had to have the lower rear mount loose. Now with it all together I cant get to the lower rear mount to tighten it properlly. But after I got everything snug it was more out of alignment then my home jerry-rigged set up. Its a $80 piece of crap!!! The pump is crooked and the top mount isnt straight when tightenned to pump. That or I just cant see straight.... :thinking:
  6. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    I agree mine was a pain in the ass and didn't bolt right on like I thought it would either :mad:
  7. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    After I read the instructions that came with mine it went on perfect.
  8. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    I should have just sent it back when I read that to adjust alignment you have to completely un-bolt and move washers. Its mine now since I had to do some grinding to get the thing to mount to water pump.
  9. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    I have no clue if you are having the same problem as I was here recently but here is some info on what I went through with my power steering pump last week. My bracket was out of alignemnt also. Not a March product but the factory one :rolleyes:
    http://coloradok5.com/forums/showthread.php?t=145747
  10. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    My oem had a bracket connected from front of head and first exhaust bolt to pump. And this was the adjuster. After Headers I had to make a spacer. The other mount was a non used hole in the water pump. The March uses a braket that has spacers and replaces your 2 drivers side water pump mount bolts. This made a bit of a mess replacing. It also used the same extra bolt hole on the water pump. I had to remove a stud in the back of the pump. Its on crooked and not lined up with the crank pully now. I'll take another look at it after work. It was just such a pain in the azz to get on. And now to try to adjust it forward a bit I have to take it all apart.
    :doah: :confused:
