marine vortec engine
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by JMZ, Feb 22, 2002.
  1. JMZ
    JMZ Registered Member
    Dec 4, 2001
    73
    Gonzales , Texas
    I have a chance to buy a 2000 , 330 hp marine engine. It has the vortec heads and aluminum high rise intake for a 4bbl carb. It threw a rod threw the side of the block. Is it worth $250.
  2. ImpalaSS
    ImpalaSS 1/2 ton status
    Feb 1, 2001
    201
    well your basicly buying the heads, and there worth 250
    68 SWB 4x4 1 of 1,449 made 327, 465, rockwell tcase, dana44, 14 FF, <a target="_blank" href=http://communities.msn.com/68K10>http://communities.msn.com/68K10</a>
  3. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    if they are close by get all the info you can on the engine and I'd ask a marine engine rebuider, some of the engines ARE different and run different cooling paths than a standard automotive engine. But if you ask a local marina they should be able to direct you to a knowlegable engine shop.
    Like em big and topless
    You call THAT...a 4x4....LMAO?
  4. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Even if the cooling paths are the same as an automotive engine, I'd advise to be wary of cracked valve guides and bent valves. Often, when a rod gets thrown through the side of a block you end up with a piston mashing the valves.
