Marmon-Herrington axle update with pics....
Discussion in 'The Garage' started by steelsoldiers, Feb 10, 2004.
  1. steelsoldiers
    steelsoldiers 1/2 ton status
    Oct 17, 2002
    365
    Charleston, West Virginia
    Hey guys,
    A little update for y'all tonight. I have been working on getting the hub base off as you can see from my other posts and tonight I finally had success. I also have some other interesting pics and info for you guys.
    After much beating, oiling cussing, etc... I finally came up with an idea. Since I had already FUBARed one edge of the hub trying to get it off I was up for anything. I drilled a hole in between two other mounting holes, tapped it, and threaded in a bolt. As the bolt went through the hub and hit the wheel hub steel it started to push against it and shove the hub out. A little cranking with a ratchet and she finally popped free. Little bastard...
    Here you can see the stub axle which is Dana 60 sized at 1.31" with 30 splines. I won't how big the rest of it is until I get it apart some more.
    A Carraro tag I found hidden under dirt on the back right corner of the chunk.
    King pin grease zerks hidden down inside the steering arms by dirt
    A shot of the 4 piston caliper, big sucker, $$$ too.
    Next step is to make a socket to remove the axle nut. I have a diagram from M-H that shows how to make one. It's a socket 79mm wide, 75mm deep, with two 7.5mm studs on the end which engage the nut. Maybe I can buy a cheap 4wd nut socket and weld some round studs on it. Here's a drawing of it:
    Any of you CAD guys want to make me one for a small fee? /forums/images/graemlins/thumb.gif
    That's all for tonight. More to come later as the teardown progresses. /forums/images/graemlins/peace.gif
  2. steelsoldiers
    Oct 17, 2002
    365
    I just had an idea about how to make a axle nut tool. How's this sound. I could buy a 6" or so piece of 2" steel pipe threaded on either end, a threaded pipe cap, and a piece of steel bar the size of the holes in the nut. Then I could cut the threads off of one end and weld two pieces of the steel bar to either side of the bottom. Then I could screw the cap on the other end and tack it into place to keep it from unscrewing. Finally, weld a 3/4" nut to the pipe cap to turn the socket with. Does that make sense?
  3. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    Damn, that thing is a beast! /forums/images/graemlins/ooo.gif Good to see your getting it ready after you bought it and I am suprised though on how small the stub shafts are if they are equal to a D60, considering the size of the rest of that axle.
  4. steelsoldiers
    Oct 17, 2002
    365
    [/ QUOTE ] I was too. I am anxious to see the rest of the axle shaft. I can always get some chromoly shafts made and keep the stockers for spares. I am probably going to welding the spiders because as far as I know there are no lockers available, so that's might be tough on stubs and hubs. I want to check out the spindles and see if there is any room to go up a size or two. If it really gets to be a problem, I'll go to Rockwell outers /forums/images/graemlins/thumb.gif
  5. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    give sandy cone the ring ring and get some bling bling shafts made from 300m. Doesn't get much better than that.
    j
  6. steelsoldiers
    Oct 17, 2002
    365
    Aaah yeah, I hear ya jek, word to the 300M yo
    Seriously though, that might be the way to go, 300Ms and CTMs in the double-cardan /forums/images/graemlins/peace.gif
  7. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    Whats 300M? /forums/images/graemlins/ears.gif
  8. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    It's a grade of steel when properly heat treated is mucho strongo.
  9. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    [/ QUOTE ] /forums/images/graemlins/ooo.gif /forums/images/graemlins/ooo.gif /forums/images/graemlins/ooo.gif Whats it cost to have a shaft made?
  10. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If you have to ask....
    It is too much /forums/images/graemlins/doah.gif
  11. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    How much?
  12. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    depends on what you want, but a set of 300m toyota 8" axle inners over on pirate costs $550. 300m is probably the best material to make axle shafts from on the planet, assuming its heat treated correctly and all that jazz. Definitely bad azz. When I win the lottery, I'm gonna go 40-spline 300m shafts + a 40 spline detroit for my D60. lol!! /forums/images/graemlins/grin.gif
    j
  13. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Yeah don't forget new spindles and hubs and drive flanges to match that...
    Anywho, yeah it's about $3000 for a set of 60 shafts from Jack at CTM.
  14. steelsoldiers
    Oct 17, 2002
    365
    Wooooo-doggy, that's some serious green Jason. If breakage is an issue, I mean, when breakage becomes an issue, I think I'll give the guys at Superior a call first and get some custom chromo shafts before I step up to the 300M.
