Marvel Mystery Oil!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazin Ed, Jul 15, 2003.
  1. Blazin Ed
    Blazin Ed Registered Member
    Mar 29, 2002
    92
    Seattle
    Got a stuck lifter sounding pretty loud... A friend suggested pouring some Marvel Mystery Oil down the crankcase to free it up. I've never used it before so I'm turning to the K5 guru's to give me their take on this. Have any of you used this to free up a lifter? I'm selling this soon so I'm looking for a short term solution..
    Ed
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> That stuff freed up a sticky lifter on my old Toyota real fast. /forums/images/graemlins/thumb.gif </font>
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    The stuff is great. /forums/images/graemlins/thumb.gif I use it as a gas additive when I am going to do a long tow. It Almost smells good enough to drink /forums/images/graemlins/grin.gif
    I also throw a quart in the crankcase in all the engines I build for the break in period.
  4. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    i had 3 valves stuck... pured down carb... while running.... it was nice.... smoked like hell but freed them up....
  5. Blazin Ed
    Mar 29, 2002
    92
    Seattle
    How much of this stuff should I use in the 350? Should I change the oil once the lifter frees up?
  6. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    The amount to use is normally listed on the container.
    You do not need to change the oil after adding it.
    I believe the stuff was first made back in the WWII days to reduce friction of oil to allow the old piston fighter aircraft to obtain more power in climb conditions.
    I have used it for years, it good stuff for keeping engine components clean.
  7. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    why when towing?
  8. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Cleared the lifter tick on my old Impalla. It also makes an ok cutting fluid when drilling and works as air tool oil.
  9. daimok
    daimok Registered Member
    Jul 18, 2002
    40
    north carolina
    GREAT stuff , I have seen it personally unstick piston rings on small engines that have sat a few years. 10 thumbs up /forums/images/graemlins/thumb.gif
  10. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    How often do you use it?? Every oil change?? In addition to the oil?? or in place of a quart?? I have to do an oil change this week, thought I'd give it a try.
  11. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    You should just use it when you need it and not all the time. We sell the crap out of it at work. Also great filter oil for RC nitro cars.
  12. 88Silverado
    Mar 13, 2003
    2,664
    I use to get the pint can and add it to the oil every so often to after changing it to keep things clean. Also use to add a pint to the gas tank every so often to keep the carb, upper areas and valves clean.
    There is also "Motor Flush" you can buy. This stuff is a solvent and will clean everything. It can also break loose some larger chunks which hopefully dont cause any problem before the filter can catch it. Basically add 1 quart before you change your oil and start the engine and let the engine "IDLE" for a couple minutes then drain it. I have used this on pretty old motors with good success on freeing up noisy lifters and upping the oil pressure.
    I would suggest you go to the store and get a can of Mystery Oil before you change your oil, read the can and add it accordingly. You should add it after the oil change. /forums/images/graemlins/thumb.gif
