Master Cylinder Question
Discussion in 'The Garage' started by onlychevy6, Jul 25, 2006.
  1. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    The rear bowl of your master cylinder feed the front or rear brakes? I had the master cylinder replaced, the booster replaced. And the rear brakes. the fronts are in good condition.
    Today as i am driving to work my brakes go real spongy. i take a look just now and the rear bowl is almost empty again. WTF?
    Please tell me what is going on. I am pissed now.
  2. dremu
    Feb 27, 2000
    15,967
    459
    East of San Francisco
    Rear bowl is for the front brakes.
    Methinks leaky caliper or hose?
    -- A
  3. onlychevy6
    Mar 29, 2003
    1,293
    Hockley, Texas
    thats what i thought. i will double check the lines. could the porportioning valve be causing this also?
  4. dremu
    Feb 27, 2000
    15,967
    459
    Wayulll, combo valves rarely go bad.
    They can stick one way or the other, though, if your brake system has air or leaks.
    When you bleed the system after replacing the hoses or calipers or whatever, be sure to reset the combo valve by pressing the rubber button on the end of it.
    -- A
  5. onlychevy6
    Mar 29, 2003
    1,293
    Hockley, Texas
    crap i dont think it was ever pressed. Never knew that the could be pressed. What does that Do? Mine is the original from 75.
  6. diesel4me
    Jul 24, 2003
    17,570
    943
    Massachussetts
    master cylinder..??
    My 82 K20 with hydroboost empties the rear chamber of the master about every 2 days..its leaking right out of the master cylinder itself!..
    I checked everything else from the master to the rear wheel cylinders,before I thought of looking there!--sure enough,a stain on the driveway where all the brake fluid landed!--and it ate the asphalt too!:mad: ..grrr!..now I need a master cylinder(35 bucks!)...:doah:--and a new inspection sticker!(29 bucks!)--AND the plates expire at the end of the month!(41 bucks!) :angry1: ..and I'm BROKE...
    Isn't life a JOY..:screwy: :screwy:
  7. onlychevy6
    Mar 29, 2003
    1,293
    Hockley, Texas
    yeah you would think that the master would be bad. Except this is brand new and no leaks from there.
  8. dremu
    Feb 27, 2000
    15,967
    459
    All of mine are original -- as I said, the combos rarely go bad. Ain't much to them.
    Best I can describe the button as a reset; there's a switch, if you will, that slides from the front circit to the rear, which as I understand it is what triggers the brake light to come on, if there's a catastrophic difference in pressure between front and rear... i.e. if one side is leaking.
    BTW, does your brake light ever go on? The parking brake should also light it, but that's a separate thing entirely.
    Anyway, the push button just re-centers the slider.
    When was the last time your brakes were bled? As I keep preaching, garden sprayer, garden sprayer, garden sprayer... :D
    -- A
  9. onlychevy6
    Mar 29, 2003
    1,293
    Hockley, Texas
    LOL... Actually my brakes were power bled 2 weeks ago. I just checked and there are no leaks coming from any of the hoses. I found the button you are talking about. and just pressed it. so we will see what happenens. As far as brake coming on. No it does not. That part of my circuit board has crapped out. Need to replace that.
