Master Cylinder Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lax037, Jun 1, 2002.
  1. lax037
    lax037 Registered Member
    May 29, 2001
    49
    Long Island
    I'm converting to a 1 ton master cylinder on my K5, only problem is that when I bolt it up, there is a gap between the brake booster and the Master Cylinder. Is this normal?
    K5 is an 86, master cylinder is for an 86 K30
    I could prob make a plate to go by the gap, but this will eliminate some of the travel of the pedal(not good) or I could just silicon it and see what happens, and suggestions or experiences with this would help
    Oh yeah, reason behind this master cylinder swap is that I figured since a previous post went on about the difference between the master cylinders, and I was replacing it, I figured why not.
    Tom
  2. dyeager535
    26,979
    Is the booster not right? I could be mistaken, but on GM cars, if the Master Cylinder bore is too big, it won't "seat" into the pocket of the Brake Booster. Never heard of the same problem on trucks (different MC bore size and boosters not interchanging) but see if thats why there is a gap.
  3. lax037
    May 29, 2001
    49
    Long Island
    it's not that the cylinder won't go in, it goes in fine, there is just a gap due to the lack of a lip on the master cylinder. I'm sure silicon will be just fine the more i think about it, I guess there must be a difference between the boosters or something(uneducated guess).
  4. Jed
    Jed Registered Member
    Nov 3, 2001
    60
    Alberta, Canada
    Don't the 1 ton and diesel trucks have 'hydro-boost' boosters run off the power steering pump instead of vacuum?
    This doesn't necessarily mean that the master cylinders can't be swapped but if you're running into problems fitting it, I'd be careful. It may be an intentional design difference so they don't get intermixed...
