Master cylinder question....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ben Malinski, Dec 26, 2002.
  1. Ben Malinski
    Ben Malinski Guest
    Will a similar year (84) 1 ton K5 master cylinder fit a 1/2 K5? Any differences? If so, what? Thanks!
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Yep, Mine bolted right on. since I used the 1/2 ton Vacuum brake booster, I had to put a spacer in between the booster and the plunger on the MC. If you get the 1 ton booster, Its all a bolt on.
  3. Ben Malinski
    Ben Malinski Guest
    Please explain the spacer between the booster and master? What? 1/2 or 1/4 inch washers? A solid piece of metal? Thanks!
  4. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    The 1 ton boosters (at least on my year), the rod that comes out of the front and into the MC sticks out like an inch or so. The 1/2 ton boosters are flush with the surface. I just used a rod that I cut down to an inch or so. I plan on getting the 1 ton booster eventually.
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the question would be "why do that?"
    is your current master to small?
    or just a 'since i was changing it' type swap?
    what bore size do you need?
  6. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    It might be for an 84 but not for an 89. I had to lengthen the shaft that goes to the pedal. This was using a 1 ton MC and Booster from an 89 1 ton.
  7. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    No kidding? I didnt know that. I wonder what the changes are?
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I am really tired here so forgive the stupid question...
    89 still old body style in 1 tons?(I recall they are but that could be the difference)
  9. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    Only in the Crew Cab I believe.
    James
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    So if you are correct, does this not solve the "why a 89 1 ton booster didnt fit the old style cab balzer" question?
    by the way, Hello there.
    I dont think we have spoken much or at all.
    If you are out in the Chilliwack area and need a field repair look me up.
  11. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Thats a good point. The 1 ton and the 1 ton extra cab where newer style while the 4 door 1 ton was still the older. I wonder what booster he got?
  12. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    I'm assuming I got the 89 1 ton from a 2dr. I let my dad order it through his company so who knows. I told him to just order the 1 ton booster/master from an 89.
  13. supernaut
    supernaut Registered Member
    May 2, 2005
    94
    Seattle, WA
    I have a '75 half ton and would like to upgrade the booster/mastercyl combo to 1 ton.
    Napa shows a one ton part #: NBB501023 for a K30 1 Ton 4WD - Pickup of that year
    Will those components bolt up OK?
    I guess I should make sure I replace the flexy rubber parts in my brake lines before I increase pressure.
    Anything else I should worry about?
  14. supernaut
    May 2, 2005
    94
    Seattle, WA
    I'm concerned about blowing out other half ton parts in my brake system with a 1 ton master cyl/power booster. If no one has any words of wisdom today then I'll just get a 1/2 ton master cyl tonight and install that instead.
  15. 3/4 Ton Blazer
    3/4 Ton Blazer 1/2 ton status
    Sep 23, 2007
    177
    PNW
    There was no 1 ton K5.
  16. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,993
    130
    I wouldn't worry about upgrading master cylinders. IME, if your brakes aren't good then the blame is with something bad in the system. I have the stock 1/2 ton Blazer master cylinder and can lock up all four tires (42's) at any speed with relatively little effort.
    Swapping from a 1/2 ton to a 1 ton master cylinder does require messing with pushrod lengths.
