Master cylinder Replacement
Discussion in 'The Garage' started by Hardcore, Dec 31, 2003.
  1. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    My master cylinder in the K5 (1990) just took a dump. Going to get one from Napa. Can I get one from a 3/4 or 1 ton from that same year? Will it bolt up to the brake booster and all and will it give me any better braking with my 1-ton axles? /forums/images/graemlins/k5.gif
  2. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I know a 79(mabe) 78 3/4ton MC will take the place of a 84... take your with you and have them take a few out Im not to sure if mine gave me any better braking though because I also changed my front callipers and pads and converted to rear disks when I changed it /forums/images/graemlins/thumb.gif someone posted the otherday about what 1ton non hydrobost fits
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    no the lines are swapped backwards from 1/2 ton to 3/4 and 1 ton, you should not need to go to larger m/c if your brake syhstem is in good shape, there is no need to swap
    good luck
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The 1-ton MC isn't really an inprovement. It has a bigger bore that will make your peddle firmer and require more effort to stop. On the other hand a 3/4-ton booster is often a double diaphram and will provide for much less peddle effort...that is how they can get away with the bigger bore (same with Hydro-Leak...I mean Boost /forums/images/graemlins/grin.gif)
  5. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    So would the 3/4 ton MC be a direct swap and will it provide any benefit to the 1/2 ton /forums/images/graemlins/confused.gif /forums/images/graemlins/ears.gif
  6. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    all I know is yes it is a dirrect swap
  7. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    Anyone else, anyone done the swap on a late model truck with ABS??? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/ears.gif
