master cylinder
Discussion in 'The Garage' started by nicotine, Feb 18, 2004.
  1. nicotine
    nicotine 1/2 ton status
    Jan 11, 2004
    116
    i bleed my brakes and i checked for leaks no leaks, also replaced my master cylinder gasket because it was leaking. but my brakes are still spongy and the brake light is on in the cab. Is master cylinder shot? /forums/images/graemlins/yikes.gif if so how much does a new one run?
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    More than likely yes, had that happen to my pops' ride, replaced the MC and it was cured. How does the pedal feel?
  3. nicotine
    Jan 11, 2004
    116
    the pedal is really soft felling and my rear drums hardly work all my stoping power is on the front disc's. how much was a new MC?
  4. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Well his was for a Chrysler mini van, but it was only like $30, i think they are about the same for the GM units also, they really aren't that much, if you don't have much power to the rears, it may be bad, but that all depends on how much, "isn't much" as around 75% of braking power is through the front disks anyway. The backs are simply for control factor and assist of the fronts. I would probably just opt for the new master cylinder, if you have done everything else, and don't have any wheel cylinders leaking,,, the pedal doesn't "fade" does it? meaning while your holding the vehicle with the brake, the pedal will slowly drop/fall to the floor or head that way?
  5. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Actually i just re-read your first post,,,what do you mean you replaced the master cylinder gasket,,,what gasket?
  6. nicotine
    Jan 11, 2004
    116
    a MC gasket is the rubber piece you see when you pop the cover off. it has the two ruber pieces that expand and contract.
  7. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Ok i just wanted to verify that. /forums/images/graemlins/thumb.gif
  8. nicotine
    Jan 11, 2004
    116
    is there a web site that i can get a estimante on a MC?
  9. 4xcrazy
    Oct 31, 2003
    9,471
    5
    We just get ours at our local auto parts store, Autozone (lifetime warranty) Checker/Schucks/Kragen, Napa. Napa is usually more expensive though. Where are you at?
  10. win717
    win717 Registered Member
    Mar 8, 2003
    60
    PA
    a new mc for my 79 blazer,the cheap one is 13.99 plus 7.50 core for reman(cardone brand)to 69.99 for a new one(bendix brand) hope that helps
  11. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    You might want to try bleeding your Proportioning valve.
  12. nicotine
    Jan 11, 2004
    116
    is the porportioning valve between the brake lines in the rear above the axle housing?
  13. 4xcrazy
    Oct 31, 2003
    9,471
    5
    When you bleed the brake lines, your bleeding everything from the master cylinder all the way to each wheel, including the proportioning valve.
  14. 4xcrazy
    Oct 31, 2003
    9,471
    5
    The valve is usually mounted up front near the MC, ihave mostly seen them on the Chevy trucks mounted on the front cross frame near where the steering box is mounted, under the radiator.
  15. nicotine
    Jan 11, 2004
    116
    oh okay i know what you are talking about now i am sure i have to bleed that to because i did not. thanks
  16. 4xcrazy
    Oct 31, 2003
    9,471
    5
    As i was saying earlier though, it is part and tied in with the brake line system, when you bleed the brakes, your bleeding this item also.
  17. landcrusher
    landcrusher Registered Member
    Jan 21, 2004
    33
    Escondido, CA
    Have you tried checking your rear wheel cylinders? Mine went out and I fried my front pads from overworking them.
    Also: If you haven't already, you may just want to check the rear adjustment.
  18. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    But he said he was not getting any pressure in the rear. I had this happen on mine and it was due to air in the PV. I still had a steady stream of fluid coming out the back but very little pressure. Once I bled the PV all was good.
  19. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    did u check to see that fluid comes out the bleeders good in the back? adjust the shoes?
