Materials opinions needed.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by laketex, Jun 26, 2001.
  1. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Making front and rear bumpers, wanted to see what yall's take on it was. I've got a choice in material between 2x4x3/16 or 2x4x11ga. 11 ga is .120 material. Do I really need the extra thickness of the 3/16? All I'm running on the bumpers is a reciever hitch thru, and 2 d rings front and rear. The 11 ga gives me 15 pounds of weight savings over 3/16 per bumper but I want to know if my strength is up to par. Thanks gurus.
    Bryan
    Sherman, Tx
    <font color=red>Come Awn yall...Let's go to LUCHENBACH, TEXAS!!!
    </font color=red>
  2. FastEddy
    FastEddy 1/2 ton status
    Feb 3, 2001
    182
    southeast manitoba, canada
    I would go with the 3/16, especially with D rings used for pulling/jerking, and depending on how heavy your rig is, even for jacking on, or the occasional tree encounters.....just my 2 cents...ED
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have always found that treat lumber work great!!!!! And it is biodigradable if you break it in the woods!
    BTW, I am no longer on Yahoo, it was freakin with my IE... :(
    <font color=green>MIKE</font color=green> - "Hukd on fawnics,werkd fer me!"
    <A target="_blank" HREF=http://www.geocities.com/emmettology101>http://www.geocities.com/emmettology101</A>
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I would go with the 3/16.Mo better for pullin and jacking.I used 2"x6"x.25" on mine with recievers front and rear.
    <A target="_blank" HREF=http://community.webshots.com/user/beaterwhang>http://community.webshots.com/user/beaterwhang</A>
  5. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I'd go with 3/16". It'll survive much better.
    If it weren't for bad luck, I'd have no luck at all[​IMG]
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A>
  6. laketex
    6,220
    North Texas
    dang it, that's not the answer I wanted..lol. here's the weights of each
    3/16 bumper at 78" (approxamation) 44.7 lbs
    11 ga bumper at 78" 29.6 lbs
    That's a lot of difference. I really want to save weight, but dont want a bumper that's too light duty. Normally I go with overkill in my projects and my shop does too. Nice bulletproof products, but you've got to know when your strength is where you want it to be. I may go ahead and make them out of 11 ga and then reinforce the reciever and d rings back to the frame. Any other insight?
    And mike, i was going to use schedule 80 water pipe with some neat balsa wood winch mounts, but balsa wood is so expensive! sorry about your yahoo experience. I use IE and have had no problems. I'll see what I can do about going icq. Later.
    Bryan
    Sherman, Tx
    </font color=red>
  7. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Bryan, my bumpers are 2"x8 1/2" ( I know its an odd size...) box tubing...0.125" wall. I ran some plates from the frame through the bumper for my clevis shackles. That way i am pulling on the frame instead of the face of the tubing. As for being strong enough? Well the rear took a direct hit from a full size Ford and only bent in about 1 1/2" at the outside. The body behind the bumper isn't even dented. BTW that 4000 lb Ford was doing 50 MPH when she hit me.
    The rear face of the bumper tubing did not deform or dent either, it just has a gentle curve to it now.
    Box tubing is very strong...normally i like overkill, but I think 1/8" material is plenty.
    Rene
  8. laketex
    6,220
    North Texas
    that's probably what I'll do rene. I just hate pouring the weight in since blazers are heavy enough as is. It's nice to see someone else with a similar setup doing well. I'll probably run the attachments for the d rings and a brace for the reciever from the frame, then use the tubing for the main bumper. My tire, jerry cans, ect are in the bed so total support is not needed. Plus the 11 ga tubing is FREE!!!
    Sherman, Tx
    </font color=red>
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Does anyone make decent pre-made custom bumpers for our trucks?
    Tim
  10. laketex
    6,220
    North Texas
    yeah SEC is the leader I think. I hear a lot of raves about them and they do killer work. But they're sooo expensive. There's a price list up somewhere. I've got access to a welder and chop saw so I build all my own stuff wherever I can!!! Plus there's the personal pride of having made your own equipment! But to answer your original question, yes there are places. SEC is good, steer clear of KMA. And bring a full wallet!
    Sherman, Tx
    </font color=red>
  11. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Are ya gonna make them full width?Mine are only a few inches wider than the frame and they dont weigh too much.
  12. Emmettology 101
    May 9, 2000
    8,126
    FL
    Ya, I think it may have had to do with a few other little problems I am having...
    PM's work good though!
  13. laketex
    6,220
    North Texas
    i dont know yet fizzle...but probably full width for protection, also putting a pick front and rear out of 1-3/4" .120 wall and it would be nice to do it all the way across.
    Just stay in touch mike, I'll probably have some pics up tommorrow or the next day. So stoked about finally getting this project on the road!!
    Sherman, Tx
    </font color=red>
  14. Steelhead
    Steelhead Newbie
    Jun 22, 2001
    I'd go with the 3/16 because besides the other reasons given if some one runs into ya you won't have much damage.
  15. tyler t.
    tyler t. 1/2 ton status
    Aug 7, 2000
    163
    Go with the heavier of the two. You will thank yourslef for it later on when you go use on of your d-rings and it does not decide to pull through your bumper. It is worth the extra weight. Just my opinion.
    Metalhead
    JEEP it's what's for dinner!
