Math homework, HELPPPP`
Discussion in 'The Lounge' started by Capman2k, Jan 28, 2007.
  1. Capman2k
    Capman2k 3/4 ton status
    Jun 22, 2001
    5,070
    dg
    I need to solve this: A circle has a circumference of 48(pi) inches. Find its radius.
    So my book has an example of how to figure out a circumference (C=2[pi]R) and I also have an example of how to find the area... But I don't need any of those things, I need the friggin radius....
    I'm not sure quite how to set it up, maybe 48(pi)=2(pi)R then solve for R????? :confused: :confused: :confused: em pleh
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
  3. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    set it up like you said then solve for r you should get a answer of 24 inches
  4. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Real simple go out and buy a contractors calculator:thumb:
  5. Capman2k
    Jun 22, 2001
    5,070
    dg
    Good work, boyz thanks:D
    20 more problems to go, stand by
  6. cabledawg
    cabledawg Secret Squirrel Premium Member
    Sep 12, 2006
    2,647
    Highway to Hell
    Actually circumfrence is D x pi. So divide 48 by pi, then divide by 2 (radius is half of the diameter) and the answer should be 7.63 and some change. I use this all the time to find out how far a particular sized tire will travel in one revolution.
  7. enginenine
    enginenine Registered Member
    Apr 7, 2006
    85
    Loxley, AL
    circumference = Pi * 2 * radius. Work backwards
  8. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    if you divide 48 (pi) by (pi) you get 48. then divide by two and you've got 24...
  9. Capman2k
    Jun 22, 2001
    5,070
    dg
    **** I hate math... I'm not finishing this assignment. If a math problem makes me swear and want to stab something I think that's enough homework for one day :rolleyes:
    Kay's change purse has nickels and dimes in it. The number of nickels is 5 more than twice the number of dimes. If the total value of the coins is $4.05, how many nickels are in the purse?
    I've spent 25 minutes on this one and no answer... Maybe I'm a retard, but I follow the example in the book and can't get an answer that could possibly be correct, the closest I've gotten is within .01 of an answer that could even POSSIBLY work... :mad:
  10. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    19 Dimes
    43 Nickles
    405 - (5x5) = 380
    2X Nickles = 1X Dimes
    380/2 = Amount In Dimes And Nickles
    190 = 19 Dimes
    190 = 38 Nickels + 5 Nickles
    Blah Blah Blah
    Hooray for my ****ed up head!
  11. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,853
    280
    Truckee, CA
    Set up eqns, n=5+2d
    5n+10d=4.05
    plug one into the other, solve. plug result into either, solve for other.
  12. CustomChevy
    CustomChevy 1/2 ton status
    Jun 29, 2005
    4,328
    Kitchener, Ontario, Canada
    n = nickles
    d = dimes
    n = 2d + 5
    so if
    5n + 10d = 405
    sub in n
    5(2d + 5) + 10d = 405
    Compleat Multiplication
    10d + 25 + 10d = 405
    Subtract 25 from both sides
    10d + 10d = 380
    total d's
    20d = 380
    devide both sides by 20
    d = 19
    So if
    n = 2d + 5
    n = 2(19) + 5
    n = 38 + 5
    n = 43
    to check
    5 * 43 + 19 * 10 = 405
    215 + 190 = 405
  13. Capman2k
    Jun 22, 2001
    5,070
    dg
    Hrmmm... I'm not quite getting where y'all are getting 5 and 10 from.
    Wouldn't it be .05(2d+5) + .10d putting the values of the coins next to the variable that determines the number of coins? Then you'd multiply the value of each coin by the number of coins to get the amount of money...:confused:
  14. Capman2k
    Jun 22, 2001
    5,070
    dg
    Oh I see, you dropped the decimals... Got it... You guys are my heroes... Now if I could get a book that explains stuff better or an instructor that gives better lectures......
