Math problemo.........tire size vs stock
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BurbinOR, Aug 19, 2004.
  1. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Say a factory tire is supposed to be 29" and you're running 35's............what is the formula to calculate the % odometer/speedometer difference for gas mileage calculations? /forums/images/graemlins/confused.gif
    Probably simple but I just cracked open a bottle of Yukon to cut it with lime juice (mmmmmmmmm Snakebite) and *had* to drink the two shots out of the bottle to fit the right amount of lime juice in. /forums/images/graemlins/smile.gif
  2. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,005
    836
    Pinckney, MI
    Easy just devide 35/29 you get 1.2! Whatever your spedo reads times that by 1.2 and you have your speed!
    Whoa just realized you want something else, need to put down the JD and go to bed
    Good luck
  3. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
  4. dyeager535
    26,975
    Best idea is to figure out how far off %-wise your speedo is reading (GPS, speedometer check station/stopwatch) and calculate from there.
    Actual tire size, growth, actual gear ratio can all play into what you are actually off. Perhaps try both methods (timed distance and calculator), but the ratios GM used for stock speedometer gears/tires are almost never what the online calculators (or sites) tell you should have been used. Might get you close, but can't be as close as timing your vehicle for a given distance with YOUR tires. We all know advertised and actual tire size is almost never right.
    Stolen from someone that has dealt with this more than I... "so change gear ratio of the speedo gears by (example) 15% to slow them down (add to driven, reduce drive)"
  5. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    [/ QUOTE ] You probably should put down the JD because you answered it correctly.
    Theoretically, since you increased the tires size by 20% your speedo should read slow by 20%. If you don't have GPS then the simplest thing to do it follow a friend on the freeway who is doing exactly 60mph and see what your speedo reads. That'll tell you the percentage it's off by.
