Mating a 32 spline 465 to a 205
Discussion in 'The Garage' started by sled_dog, Jan 29, 2005.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Have someone interested in the 32 spline 465 I have sitting around. He wants to know what it would take to mate a 205 to the back of it. My thought it get a 10 spline output shaft and adapter but what other options are there? He says the 205 is a 78, trying to find out what it came behind.
  2. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    32 spline input for the 205 is the easiest fix.
    Edit; never mind that would be a 465 for a 208 which has a long shaft. You would need to make an adapter to make it work.
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    would the 208/241 adapter work? On my 203 for my doubler, I plan to drill and tap to use the 208/241 adapter. Could the 205 be setup like that?
  4. spoolnaround
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Either way you need to replace the output in the trannie. 10 spline is the cheapest way.
  5. spoolnaround
    Apr 8, 2002
    1,419
    Kingsburg Ca
    not sure, I dont know anything about the newer transfercases.
  6. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    i think that the 208/241 adapter should work on the 6 bolt round pattern NP205...but then you'd have to rig something up for the shifter. the factory 32 spl 465/205 adapters have a shifter boss cast into them.
    what he should do, imho, is forget the 10 spline. use a stock 10 spl 465/205 adapter and then a special plate that ORD makes, its like 1.5" inches thick or so. it bolts between the adapter and the transfer case. but then, you'd need a new input for the 205, and the case bored. for simplicity & cheapness' sake, 10 spline would be your best bet.
  7. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    32 spline short input gear from ORD ($200) and bore out the NP205 case ($40-50). Then use the figure 8 style adapter for the SM465 and a spacer from ORD ($??)...
    Or just sell the current NP205 for $150-200 and buy a 32 spline NP205 with factory 32 spline 465 adapter for $150-200.
  8. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    good luck finding that for that price...i'm sure its happened, but of course whenever you need it, no one has it or seems to think its worth $400. and then, its never local so dont forget the $75 to have it shpped from Washington state, or wherever.
  9. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Not quite... I have bolt adapters. The round 205 adapter is ~2" longer than the 208/241 adapter.
    You're right on the shifter boss difference. Also, the 205 adapter is notched for the shifter rail.
