mating a 4l80e and a np203 ????
Discussion in 'The Garage' started by beastk5, Jan 27, 2005.
  1. beastk5
    beastk5 Newbie
    Jan 27, 2005
    3
    ohio
    4l80e question ??
    i want to convert a 4l80e 2x4 tranny to a 4x4 and adapt a new process 203 to it because i want to run a off road design 203 /205 doubler setup...
    can it be done??
  2. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    is this a question or a statement?
    mabey post what ou want.
    do you want to know if you can?
    what you will need?
    if it has been done?
    a little info. will help people give you better responces.
    welcome to the site, you can also use the search function at the top of the forums page to look up info that has already be talked about, might help.
  3. nvrenuf
    Jan 7, 2002
    13,075
    246
    Mobile, Al.
    How much does the tailshaft stick out of the case?
    The TH400 with a 203 tailshaft sticks 1.5", iirc.
  4. sweetk30
    Nov 1, 2004
    25,538
    538
    horseheads , ny 14845
    dont know about the 203 setup but when you convert 2x4 4l80 to 4x4 remove the plug on the 3 oclok position that has a pinhole in it . replace with 4x4 plug thats no hole. if not you will lose pressure in tranny and bun it up. i am doing a 4l80 to 205 setup and almost found this out the hard way. plug is about 3-5 dollers at dealer. its about the size of a dime. this is for the oil supply to the bearing in the tail shaft assbly that the yoke rides on. not needed in 4x4 app.
    advanced adaptors has the gm part # for the 2 year only tail shaft for the 4l80 thats full length splines. but not sure its full as far as you need. call or go to there sit and see if thay offer a kit for this.
    whent to there site and didnt find specific adaptor. www.advanceadapters.com
