Max backspacing on 16.5" wheels and a D60 front
Discussion in 'The Garage' started by 88K5Jimmy, Oct 7, 2002.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Max backspacing on 16.5\" wheels and a D60 front
    What's the max backspacing you can have with 16.5" wheels and a D60 front?
    Thanks /forums/images/graemlins/truck.gif
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: Max backspacing on 16.5\" wheels and a D60 front
    I don't know but my Weld Racing wheels have a 4 5/8" back spacing.
    I doubt you would want to go any deeper than that.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I think The ORD blazer has like 7" of backspacing! /forums/images/graemlins/eek.gif
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yeah, but the ORD Jimmy does not have front springs. It has coil-overs. Coil-overs allow more room for the tires/wheels to move in and out. But, if you go to the ORD site, you will see the pic of the link bars and there will be a rubbing mark where the paint has been rubbed off by the tire contact. /forums/images/graemlins/shocked.gif And this is with the 7" back spacing you say. /forums/images/graemlins/laugh.gif
  5. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    The ORD Jimmy has 5" of backspacing on the 16.5" Trailready beadlocks.
    Will
  6. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    thatk30guy
    Here are the plans with my dad's new toy:
    4" lift
    38 x some size tire x 16 or 16.5
    Fender trimming
    Possibly relocating the axles within the wheel wells
    (centering them ORD offset add-a-leaf)
    Ohh forgot to mention it's an m1008 /forums/images/graemlins/cool.gif
    That's why I was interested in the backspacing of 16.5 wheels. He doesnt want to grind the D60 calipers to fit 15" and I don't blame him, so we have been looking into 16" and 16.5" wheels. We have seen that there is more of a tire selection with 16.5" so that might determine what size wheels he runs. What do you think?
    Thanks /forums/images/graemlins/k5.gif
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Whatever you guys decide, I would recommend using the 16" rims since they have a lip to seat the beads.
    16.5" rims are designed where the bead will pop every time you air down the tires too low. /forums/images/graemlins/frown.gif
  8. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    You might want to look into hummer beadlocks--16.5, street leagal beadlocks--not real cheap though after you have to modify the centers to deal with the 7" of backspacing they come with /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif. Just my .02 /forums/images/graemlins/thumb.gif
    Eric /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  9. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Would it be OK to use aluminum spacers on the front axle as well as the rear axle with the hummer beadlocks? I plan on using the stock front axle on a 3/4 ton burb till I can get a D60 dually front to acomodate to offset. I will use 4" aluminum spacers in the rear and will use them in the front for awhile (if it's OK) too.
  10. OL14BLAZ
    Aug 14, 2002
    1,815
    TEXAS, USA
    Sorry not able to help you on this one--don't have any experience with wheel spacers. Maybe someone else could guide you in the right direction /forums/images/graemlins/blush.gif
    Also try doing a search in this forum I think I remeber someone else having the similar question about spacers with hummer beadlocks /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
