Max. Lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mxk419, Jun 14, 2003.
  1. mxk419
    mxk419 Registered Member
    Apr 29, 2003
    5
    What's the maximum lift I can put on my 90 Blazer without changing/lengthening the driveshafts? If I were to add an 8" lift, how much would it cost to lengthen the shafts? thanks
  2. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    I have a 4" skyjacker and no driveshaft mods. I've seen a 6" with no mods but he was right at the edge of the driveshaft travel. I would think 8" would definitely need some more length. Around here I think you can get your shafts lengthened for $50-75 per shaft.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    In your quest for giant tires, don't forget the drivetrain. If you're gonna run really huge tires, then you'll need to seriously consider upgrading to stronger axles than the stock 10-bolt, 1/2-ton models. Plus, if you actually want to have a truck that you can drive, you'll need to swap out the axle gears for something that matches the tires. Otherwise you'll have a slug that is not much fun to drive. /forums/images/graemlins/frown.gif
  4. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    price for lengthening driveshafts is peanuts compared to what it will cost for high angle cv's. i have 6 inches on mine and the stock ones work but there is not much spline left. the real prob is my front cv doesnt angle enough to turn the front axle. i ended up blowing it out. you will definetly need longer and high angle driveshafts for 6 or above inches of lift. im just saving up for mine still.
  5. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    hell, i only did a 2 1/2" lift and had to get my rear driveshaft redone. i went ahead and got a CV shaft so i don't have to later when i do a 6" lift. (front springs, and ORD shackle flip in rear) i'll probably have to get it lengthened though.
  6. Orange Crush
    Orange Crush 1/2 ton status Premium Member
    Mar 6, 2003
    440
    St.Stephen S.C. 29479
    A grinder does wonders for clearancing that front CV.Grind away whatever hits.It may not be right but it will work. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  7. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    Crush is absolutely right. Consider saving your money on purchasing a high angle CV for the front, just grind! I had a 9" suspension lift and grinding allowed the CV to move freely, but I still had to have it lengthened. There's a lot of work to be done when you get up past 6" of lift, but there's definately nothing cooler than a Blazer with a 12" lift, 39.5" Boggers, and 3/4 ton axles.
