max tire size w/ extra flex from ORD swaybar diconnect
Discussion in 'The Garage' started by big_truxx, Aug 23, 2005.
  1. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    would a 31" tire still be ok with stock suspension under full flex with the ORD quick front swaybar disconnect?
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Should be fine
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    you cant run dissconnects with stock suspension. the will not clear the frame
  4. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    :doah: i did not know this. what do you need for the quick dissconnects?
  5. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Seriously, the swaybar is not needed. I was leery about having to remove mine when I swapped in the D60 w/ crossover, but I have had not a single problem with it being gone. I drive some very winding roads on pavement on my way to my hunting cabin, and I do it at speeds up to 65mph, I have a LITTLE bit of body roll, but nothing that I would worry about, AT ALL.
  6. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    if you can deal with the body roll of a k5 vs. an average modern vehicle, removing a sway bar is nothing.
    i removed mine when i lifted it and never looked back.
  7. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Sorry....you can't make a blanket statement like that about sway bars.
    Stiffer springs and shocks can help mask the effects of removing a sway bar, but not everyone goes to a setup like that. Personally, I'd KILL to still have a front swaybar on my K5 if I could figure out a simple way to do it. (D60 w/Crossover :crazy: )
    With my soft, flexible springs up front, I've got massive body roll, and it's downright scary to see my truck on a winding road....
    Disconnects can be a godsend for someone who want's to really evaluate the effect of having a sway bar (or not!)... :thumb:
  8. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    What swaybar? :D Thats what I said when I gladly trashed mine long ago. Gregs right though for smome they might be good but depends on your app. (springs, lift size, tires, shocks, what you want to use your truck for). But if you want to start getting serious ditch the thing and go grab yourself some 38 inch swampers. :wink1:
