maximum backspacing?
Discussion in 'The Garage' started by hunter, Feb 26, 2005.
  1. hunter
    hunter Registered Member
    Oct 28, 2004
    52
    Houston,Texas
    I have a 1989 Jimmy, 4" lift and 33's. I want to get some new tires/wheels but alot that I want in the size/style are 4.5" backspacing.
    Is 4.5" backspacing too much and would hit the tie rod ends?
    What is the maximum I can run?
  2. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I had some with 4"....it rubbed the right front tie rod end, but cleared the left side....stock is 3 5/8", thinkin you may be able to push it to 3 7/8" on some vehicles.....4 1/2" will not work....I'd trial fit anything other than stock backspacing before purchase, or figure on using a spacer (which may require longer studs)
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    I ran 4.25 on my truck and had room to spare. That was on a stock D44 in a '78.
  4. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,021
    849
    Pinckney, MI
    I have 4.25 on mine with no issues!
  5. Jimmy4matt
    Jimmy4matt Registered Member
    Feb 7, 2005
    74
    Campbell, California
    I'm running 4 3/4" 0n 15" wheels on my '71 dana 44 with no problems.
