Maximum Lift w/driveshaft angles...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Mar 20, 2001.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    What's the maximum lift you'd safely run on the road with out completely throwing out the driveshaft angles??? Is it now wise to run a 12 inch lift w/o getting special driveshafts... etc...
    Um... yes officer I know it's too big...
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I don't think that you can run a 12-inch lift without some major driveshaft modifications. I doubt if the stockers can even reach the axles after that much lift. When you get up that high you're usually also looking at axle mods so that the pinions are pointed straight at the driveshafts. On the rear you can just more the spring perches to do this. But up front it involves puling the tubes out of the axle housing and rotating them so that the pinion is pointed in the proper direction while the steering knuckles remain aligned properly.
  3. achuskies69
    achuskies69 1/2 ton status
    Jan 7, 2001
    229
    Raleigh, NC
    <font color=green> <A target="_blank" HREF=http://www.highangledriveline.com>http://www.highangledriveline.com</A> These guys can probably answer any questions u have about your driveline angles They have done work on trucks running upto 18" of lift, so the know what there doing...
    <font color=green> 82 K5 - 350, 4" lift, 33's 3.08's
    I love cowboy hats
