May have screwed my D60 up tonite
Discussion in 'The Garage' started by sapper, Oct 5, 2004.
  1. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    I must be ate up with the dumb ass because this lastest round of mods is killing me. On my 60 i ordered the u bolt kit from ORD for the two housing bolts it came with studs to put in it and then bolt the plate down, well they didnt fit, i figured it was because im using a dodge unit and used bolts, i thought 1/2" was the right size untill i started tightening them down tonite and it felt like i stripped them out. Now i plan on trying a 9/16th but if i did stripp the housing is there a way to drill and tap it to a larger size???? TIA
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    They're 5/8-11
    Doubtful you hurt the threads.
  3. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I snapped the bolt off in mine /forums/images/graemlins/blush.gif Drilled it out and used a Time Cert (sp?), sorta like a Heli Coil. Worked fine, but like mentioned above ... you probably didn't do a thing if you had a 1/2" in a 5/8" hole.
    Eric M.
  4. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    OMG, I am agreeing with Tim, write it on the calendar /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif. But on the serious side, you probably did not hurt the threads, the bolt threads will probably give loss before the housing's did, get the right size and you should be golden /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    Krennen
  5. sapper
    Jul 11, 2001
    3,052
    NoVa
    5/8th, thanks everyone i will give it another shot tommarow, /forums/images/graemlins/usaflag.gif
  6. sapper
    Jul 11, 2001
    3,052
    NoVa
    Just an update the correct bolts are 9/16th, no idea why other than its a dodge unit, the axle tubes are 3 1/8th wide not 3 3/8th like a chevy but on a good note it does match my 14ff without the spacers so track width has become norrower to fit better on the trail /forums/images/graemlins/thumb.gif
  7. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    arent all D60 tubes 3.125"? my Dodge is, and BillaVista's d0 bible says theyre all that size. it makes the d60 look like a weenie!
