Maybe a new truck take a LOOK!!!
Discussion in 'The Garage' started by TC4x4, Dec 26, 2006.
  1. TC4x4
    TC4x4 1/2 ton status
    Sep 12, 2006
    831
    Michigan
    I am thinking about buyiung this becasue i am gettinga crazy deal. Its a 2wd truck converted into a 4wd truck the shifter is not hooked up et but i was wondering if you all could answer a few questions,
    1. what kind of axles are these?
    2. What kind of tcase is this, look like more than just a t case there?
    3. Are 2wd trucks any weeker than 4wd in any way.
    4. is it rreally bad that the torque converter is open like that?
  2. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    1. 14bff rear/ dana44 front
    2. NP203
    3. frames are the same, someone will correct/bash me if Im wrong.
    4. only if you get mud/water/rocks in it.
  3. TC4x4
    Sep 12, 2006
    831
    Michigan
    is a dana 44 front strong?
  4. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    2wd frames usually have beefier brackets and crossmember. Weird but that's what I've seen.
  5. GotLabs
    Jul 30, 2005
    2,795
    Transient, USA
    It can go either way, but for the most part its equal to a 10bolt. It can be built to be strong though.
  6. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Looks like its just missing the inspection cover for the tranny. No big deal, except you don't really want dirt up in there.
    You probably want to get that covered up asap though.
  7. 1979chevystepside
    1979chevystepside Registered Member
    Feb 5, 2006
    46
    Huntsville AL
    my truck was missing the cover on it when i bought it, no big deal...just find a cover for it
  8. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    I don't run the cover for my converter. All it does is collect dirt and water. at least if you have it off it will dry out quicker and you can easily clean out anything in there.
  9. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I say go for it, already has rear discs......Anymore pics??
  10. scotto0609
    scotto0609 1/2 ton status Premium Member
    Feb 3, 2004
    1,526
    3
    babylon,ny
    WHat the hell is that bar in front of axle!!???
  11. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    looks like a sway bar :wink1:
  12. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Ha, didn't even see that till you mentioned it!!! I hope it's not the draglink, or swaybar, you can see where it was heated to possibly straighten it.
  13. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    pics of the frame on how it was made 2x4 to 4x4. just to be safe.
    and 2x4 trucks have a 3" shorter front hanger for the rear springs. so if you do a 4" lift you will need a 3" taller kit for the rear to sit level.
    but more info on the conversion job. was it body swap or act frame swap stuff.
  14. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    thats a swaybar that is not bolted to the frame, because its different on a 2wd than 4wd... take it off, tis for poonannys anyways lol
  15. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Could that be because virtually all Blazers are 4wd (1/4 ton) and anything else (Trucks & Burbs) are at least 1/2 ton (2wd & 4wd)? :D
  16. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,621
    610
    Hooper, Utah 84315
    :confused: Is it the pic or is that T-case not in there right:confused:
    Looks like its missing a mount:confused:
  17. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    Not particularly
  18. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Nope, take a look at 2 1-ton frames side by side sometime. ;)
  19. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Cool :D
