maybe not quadrajet problems???
Discussion in 'The Garage' started by down4thakrown, Sep 21, 2004.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    ive asked every one i know and no know whats wrong. i got 64cc cast iron world product heads & aluminum intake. when set the needles at 2 turns out it seems to run rich and when i go from a stop and it shifts into 2nd it starts to feel like its runnin rich and misses.but the more i drive the less it does it. also when i screw them in all the way it still runs fine ive rebuilt this carb to many times to count.could this be do to bad spark??now i replaced carb with brand new holley rebuild and doesn't miss until i punch it the it sounds like it wants to die and backfires outta pipes and through the mid range it makes a blubbering noize /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. dyeager535
    26,982
    191
    Re: quadrajet problems
    Not sure if you understand the carb nuances, but you do know that the mix screws are ONLY for idle, correct?
    If you have problems outside of idle, then the mix screws aren't it. I'd be leaning more towards float problems.
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    If it is still running with them turned in all the way, you have a vacuum leak.
    Dan
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Like DD said , vacuum leak . Is it really old ? I replaced mine because it was leaking around the throttle shafts and didn't feel like bushing it yet ( gonna put it in my "new" project ) . Spray some carb cleaner around the base ( be extremely careful !! ) and see if it improves . After you find and plug the leak , retune and see if you can get it nice . Maybe even bring it by sometime /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  5. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    yea its a pretty old carb i just replaced the cap and rotor now it runs worse and it misses everytime i take my foot off gas then press /forums/images/graemlins/angryfire.gif
    ill try the carb cleaner
    how do i adjust the float?
    thx
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    could i spray some carb cleaner around the carb when its runnin to see if its a vaccuum leak?
    how cdo? i adjust the float
    Yes , if your careful , wd-40 will work too , but need some wiping off . Be careful.
    And you need to pop off the top again to adjust the float , you just bend the bracket attached to the float . There are other adjustments inside that carb , but stick with the basics for now .
    Also do a search on Quadrajets , you'll turn up some good sites and info /forums/images/graemlins/thumb.gif
  7. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    the little bracket as in the piece that hangs the little pointed thing with a black tip?
  8. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    http://dyeager535.topcities.com/CCCqjetdiagram.html
    according to this diagram i have the lean mixture screw #226 tightend all the way down. you think this could be the problem??i think its the piece that stops the primarys goin any further down. the pin that goes through the hanger for the primary needle hits it so they dont go down any further. /forums/images/graemlins/dunno.gif
  9. rhuarc31
    rhuarc31 Registered Member
    Oct 21, 2003
    94
    Decatur, IL
    Well if you're running rich at idle and when it upshifts, that doesn't sound like a vacuum leak to me, a vacuum leak should make it run lean not rich. Sounds to me more like the lean stop screw is adjusted to far up. Sounds to me like the power piston is sticking in it's bore or it's spring is getting weak (if you've elimated the usual suspects, ie float level, needle and seat problems, sticking choke). Could even be the lean stop adjustment screw for the power piston (located right in front of it) if it's up to high it won't let the metering rods far enough down into the jets. Other thing that can happen is the check ball on the acelerator pump doesn't seat all the way and the vacuum through the primary bores will pull fuel through the pump causing a rich condition that goes away with throttle.
  10. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    alright its still doin it but worse. it has a real bad miss off the line or anytime i take my foot off gas and reapply. i just did all the gaskets, the check ball, float etc....but whats wierd is when i totally advance the distributor it comes and goes. /forums/images/graemlins/angryfire.gif i tried moving the wires one spot over but then its to far advanced.and when i turn the screws all the way it changes a little unlike before i couldn't tell a differance.also when i punch it,it starts to back fire outta the pipes and misses real bad. somtimes the four barrels open but theres no power and it doesn't pull /forums/images/graemlins/dunno.gif could it be valves or timing chain stretch im outta ideas and patience help plz /forums/images/graemlins/1zhelp.gif
  11. blazer74
    blazer74 Member Premium Member
    Oct 18, 2001
    1,164
    80
    Brighton Tn
    Try another carb, if you have one or borrow one. I have a quadrajet that runs too rich even with the mixture screws all the way in, no matter what i did was no help. Took it off and problem solved. Also you might want to try a new coil, they will do strange things. I blew a muffler apart because of a bad coil and would barely run "sometimes"
    Good luck
  12. mrk5
    Apr 20, 2004
    12,351
    1,050
    Northern Colorado
    After rebuilding my Qjet, I could completely seat the mixture screws and it wouldn't change the idle quality. The advice I got from a mechanic buddy was that there was crud in the idle circuit. I pulled the carb off and blew carb cleaner through every hole I could find. That solved the problem.
    Maybe my experience will help. /forums/images/graemlins/dunno.gif
    Idle mixture is for the idle only, but if it isn't set properly it will affect the transition from idle to power.
  13. 76SILVERADO
    76SILVERADO Registered Member
    Mar 1, 2003
    52
    AZ
    Take carb off your '79 and put on your '77........
  14. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    It might be in the distributor,not the carb--it sounds like you may have a pick-up coil with a break in one of the wires,moving the distributor around may be making the wires contact better--check the ignition coil and module too,I've seen cracked coils cause intermittent problems like your describing--the module has a curcuit to increase the dwell after 2000 rpm that might have failed,but will still let it run,though poorly,check the advance weights(on an HEI only,computer comtrolled trucks have none) and make sure the pins they ride on arent all grooved,causing them to stick.Vacuum leaks are a possibilty too,as the other posts have stated.A compression test will spot any bad valves,or a vacuum gauge will help pinpiont any leaks,watch the gauge as you spray any suspected leaks--it will help locate a bad valve too,it will drop a few inches every time that cylinder with a bad valve fires. /forums/images/graemlins/crazy.gif
  15. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    the coil looked brand new when i pulled it but, ill take it off again and look at it better and while im at it i'll get it tested with the ignition module. im thinkin valves too. i'll do the compression check to make sure.
    thx, this site rules /forums/images/graemlins/peace.gif
  16. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    Re: quadrajet problems *79 silverado az*4 sale
    please post this in the correct forum.
    thank you
  17. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    Re: quadrajet problems*79 3/4ton silverado 2wd 4sale az*
    ttt
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    i also got a truck for sale in az 79 3/4 ton 2wd silverado
    has front end damage but, the windows still work, v8,quadrajet, 14blt ff w/ 410,oil cooler,th400, new ac lines just need charge, custom aluminum wheels, all emission stuff there looks like it has a new air pump and vaccum canister .runs sat for a while. great tow rig. 900$obo.
    just goin to buy new engine and carb, rebuild the one thats in there and put it in /forums/images/graemlins/k5.gif 602 841 7533 daniel
    Wrong forum. /forums/images/graemlins/whistling.gif
  19. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    no $ to put in other forum /forums/images/graemlins/whistling.gif
  20. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    now i replaced carb with brand new holley rebuild and doesn't miss until i punch it the it sounds like it wants to die and backfires outta pipes and through the mid range it makes a blubbering noize /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
