McMaster Cylinder?
Discussion in 'The Garage' started by dontoe, Dec 13, 2004.
  1. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Master Cylinder Swap Question?
    Will a 1982 K-10 master cylinder work on my 1973 K-5. I have two '82 K-10's for parts and would swap the booster and/or master cylinder if it will work.
  2. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    No one know?
  3. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    they should work
  4. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    A 73 may or may not accept the 82 master. Check the rod that comes out of the booster by the firewall bracket. The late 70s and 80s have a longer threaded rod if I remember correctly and the earlier ones have an eye loop where a pin goes through. If you have the same version on both trucks it will be an easy swap to take the whole booster and cylinder.
  5. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    O.K. there's something I can look at easily. Thanks. C-o-l-d weather and very windy lately. Hope to have a building up by spring so things won't be so difficult.
