me and my bad luck
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shupach, Aug 23, 2001.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    oil is leaking out of the dipstick extension where it enters the block cause i put the protector tube in backwards, i know i know i shouldnt of done that, however i just went at it with that gasket maker in a bottle crap, and now its leaking, ne suggestions? will silicon rtv help any?
    phill
  2. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I would....
    Drain all of the oil...if its new oil buy a new container to drain it into
    use carb cleaner or engine degreaser to clean the matting surfaces
    clean the allen bolts then go at it again with fresh sealant and take your time to make sure you don't pinch the dipstick tube and get a good grip on the tube...tighten it down and it should stop unless the tube is bent -- allowign oil an esacpe-- or if you somehow --i'd think is unlikely-- bent the clamp side
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
    1982 Chevy C-10 Longbed
