measured body line, how much lift did I end up with???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by solowookie, Jun 6, 2001.
  1. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    OK I measured from the ground to the body line, and it measures out at about 49 1/4" so how much lift did I end up with???
    [​IMG] <font color=blue> Jeff </font color=blue> [​IMG]
  2. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    For comparison...my Generals that are on tRusty right now are 33" true diameter. Body line measures 49", 4" suspension and ORD 1" Body lift. Suspension may be sagged a bit and the truck is pretty full of junk right now.
    What is the true diameter of the tires on it?
    Rene
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    That question is way easier to answer if you measure the before and after. [​IMG] [​IMG] [​IMG]
  4. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    yea I'm sure your right, but thats a bit hard to answere now... LOL [​IMG]
  5. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    4" BDS lift with 315r75x16 (35x12.5x16)...
  6. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Jeff, I measured my stock 83 Jimmy 31" tires before I started working on the rebuild and here are the numbers.
    Front = 42.5" & Rear = 44"
    Bill Hughes
  7. dyeager535
    26,979
    Curious if anyone knows if the body line on the rear quarters (from doors back) are perfectly straight. In other words, if you were measure at the rear of the doors, and right before the taillights, on a perfectly level truck, would those two measurements be the same? I'm going to have new springs bent/installed to correct the extreme sag on my truck (probably 3" sag in rear, unloaded) but before I drop it off (shudder, someone working on my truck besides me) I need to tell teh guy exactly how "high" I want the rear end to be. If the body line is perfectly even from door to tail light, that will make accurate measurement on flat ground much easier.
    Dorian
    My tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
    No anti-theft measures on your truck? No pity when its stolen
  8. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    Dorian, that body line behind the doors is perfectly straight. If you remove the top and compare it to the top of the box sides you'll see that. I measured mine right behind the doors...more or less the middle of the truck.
    Jeff, what is the true diameter of your tires? Sidewalls lie...[​IMG] I measured T2 (unlifted and on some 31" AT's) the true tire diameter was 29 1/2" and the body line in the same place was 44". This however is not too accurate as the truck has no motor and barely an interior right now. I could see the number being 1" less with all components installed.
    Rene
  9. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    the actually heights according to the Big-O website is 34.7" she looks pretty tall, but the numbers don't quite stack up for the front drive shaft being as short as it is (3").
  10. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    OK, I have an extra inch of lift, but my tires are 1.7" shorter than yours. Doing a little figgering our trucks should be near the same height, and they are (within 1/4"). So I would say you got a 4" lift...[​IMG]
    Rene
  11. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    yea it sounds like I got a 4" lift... I need to ramp the thing to see if I'm gonna have any rubbing... [​IMG] then I'd getta play with the sawzall! [​IMG]
  12. i get 48" with 4 inch lift and bfg 35s- actual 33 1/4. my springs are worn too. damn, rene, i gotta get that i inch body lift! you beet me by an inch! i thought you had 36 inch swampers. you take em off for your big road trip?
    <font color=blue>Striving for K5 world dominance</font color=blue>
    <A target="_blank" HREF=http://bluebeast.coloradok5.com/>http://bluebeast.coloradok5.com/</A>
  13. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    With the Swampers the line measures at 50 3/8"...[​IMG]
    Yes I took them off for my trip...I doubt they would have lasted. My generals wear like iron and you'd never know I just put another 5000 miles on them.
    Rene
  14. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Well I haven't measured mine.... but I definetly agree that the BDS lifts are nice and big... cause I'm supost to have 5.5" springs up front and a 5.5" block in the rear plus I added a zero rate spacer and the rear is still 1 1/2" lower then up front... and I never had any sag before.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <A target="_blank" HREF=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</A>
  15. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Hey Rene, what are you guys considering "body line"? I get 44" to the opening of my wheelwell in the front.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.coloradok5.com>http://www.blazzinor.coloradok5.com</A>
  16. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    There is a 'feature line' on the body...its about 6" below the door handle and runs the length of the truck...
    Rene
    <P ID="edit"><FONT SIZE=-1>Edited by tRustyK5 on 06/07/01 11:38 AM (server time).</FONT></P>
  17. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    1 1/2 inches! grown[​IMG] lmao... man I feel your pain! you probably got a 7 - 7 1/2 in lift instead of your 5, and I probably got a 5 1/2 to 6"... even measuring the body line I don't believe my front drive shaft was 3" short with just a 3" lift!
    lmao... sorry, really... [​IMG][​IMG]
