Measurements of your rig
Discussion in 'The Garage' started by 78Buford, Sep 26, 2006.
  1. 78Buford
    78Buford 1/2 ton status
    Apr 1, 2005
    264
    Ohio
    While piddling around last night, I took measurements of various clearance areas of the Ford. I’m interested to see what other people have. When I did this, the tires had close to 30 psi in them. Also, I measured the rear of the truck lowest point under the tailgate before and after taking all of the stuff out of the bed…it only raised 1” per side with all of it removed. Here is what I measured:
    Front left corner (bottom) of bumper: 29”
    Front right corner (bottom) of bumper: 29”
    Front Diff: 13 & 1/8”.
    Front pinion yoke: 19”
    T-Case: 23”
    Rear pinion yoke: 19 & ¼”
    Rear Diff: 13 & ¼”
    Left rear corner: 39”
    Right rear corner: 38.5”
    All four tires: 40” to 40.5” (I think they’ve “grown” in the center due to being flexed & being aired all the way up on the skinny wheels…When I bought them, they were only about 40” without wheels). BTW, the wheelbase is 133".
    I'd be interested to see some other rig's measurements.
    Roy
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    A furd? You may have to wait a while to get ford measurements around here !
  3. 78Buford
    Apr 1, 2005
    264
    Ohio
    Whooa. After 178 posts, I just noticed that this is a GM site. Thanks dude! :rolleyes:
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    GM? Damn...I got a Honda!:haha:
    variety is the spice of life!:D
  5. draggbody
    draggbody 1/2 ton status
    Jul 13, 2005
    282
    columbus GA
    regardless of the make... i still think this is a good "measuring stick" to see how someone else has made changes to the same parts we all use...
    i think frame height would be a required # though...
    wasn't there a fomula that figured break over angle somewhere???
  6. 78Buford
    Apr 1, 2005
    264
    Ohio
    I didn't think to measure the frame height....have to get that one tonight.
  7. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i wont be by my truck until this weekend, but i do know that my wheelbase is 112"
    so ur 42's only measured out to 40" when you got them new?
  8. 78Buford
    Apr 1, 2005
    264
    Ohio
    Yep...42" TSL's seem to come in several sizes ranging from 39.5" to 42." Gotta love the quality control. :rolleyes: :D
  9. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    :laugh: .....
    Marv
  10. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    The one measurement that I have is about 12"±¼" to the bottom of either diff with D44/12bolt 1/2ton axle combo and 37"MTRs that measure out to about 36" actual. That's one of the things I like about 1/2ton axles.
    I paid all that money for the beefy covers and once I went to 37s I rarely hit them. :doah:
  11. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    frustrating....my 39.5x13.50 iroks measure out to about 38x15...wtf:mad: i do love the way they ride, but still i mean come on interco...
  12. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    Front left corner of bumper, 38.75"
    Front right....................... 39"
    Front diff.........12 1/4"
    Front pinion yoke 18"
    Under belly of T-case ~26-27" (not installed yet...made best conservative guess)
    Rear pinion yoke 18 1/2"
    Rear diff.........11 1/2"
    Left rear corner under bumper, 42"
    Right rear corner under bumper, 41.5"
    Wheelbase, 109"
    Tires, ~20 psi, 38 1/4" - 38 3/4"
    Lift is 6" Alcan front, 2.5" Alcan rear with shackle flip, Tires are 39.5's (that measured pretty true if not oversize when new)
    Rear corner measurements should come down an inch or two once the tranny and doubler go in (and hardtop goes back on). Belly clearance I had to take an educated guess at. Based it on crank centerline, fudged the slight downward angle of the drivetrain into my calc's and subtracted a bit to be 'safe'.
    *edit* Frame height under center of truck, flat part of the frame...29 1/4"
    Rene
  13. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    my wheel base is at 110 with a 6in lift and 35s the only measurement Ive taken is 25in from the ground to bottom of rockers.
  14. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    Ground to bottom of rockers on mine is 31 3/4"...
    You sure you have a 6" lift?
    Rene
  15. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    He only has 35's tho, but that does seem slightly low..
    Ill get my measurements in the morn when i can see to get to it.
  16. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    39.5's have about 2-2.5" more radius than 35's. I do have a 1" body lift, and the truck is missing some weight. All that accounts for about 4 1/2" max. Call it 27"...
    It just seems to me it's 'possible' he may have a 4" lift rather than a 6" lift.
    Rene
  17. Loose Nut
    Loose Nut Banned
    Nov 6, 2005
    445
    Maryland
    double post :(
  18. Loose Nut
    Loose Nut Banned
    Nov 6, 2005
    445
    Maryland
    the ticket i got from the maryland state police say's
    Front Frame height = 30.5 inches
    Rear Frame height = 35.5 inches
    Maryland state limit, 28 inchs.
    6 inch's of lift, 38.5 inch swampers.
    Enjoy your wonderful 60$ fine you redneck.
  19. Citizen Rider
    May 5, 2005
    1,415
    Plano, Texas
    Some are guessed cause the blazer is on uneven pasture.
    Wheelbase- 107.75" (about to add about 4")
    Front bumper- 30"
    Rear bumper- 29"(need to fix that)
    38" TSL-alil over 36 on 10" wide rims
    Rear wheel well- 44"
    Front wheel well- 46"
    Rocker- 27.5"
    D60- 12"
    D60 yoke- 16.5"
    14b- 11"
    14b yoke- 17.5"
    Frame- 27"
    t-case-22"
  20. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    wheelbase=110" going to 52's in the front so it will change
    front bumper=no
    rear bumper=no
    44" gumbo monster mudders on 12" rims=42 inches(they are getting bald)
    wheelwells=they clear the tires
    T-case=getting clocked this weekend
    I know the roof is just over 8 foot and when its on my deckover I can not fit under 10' 6" underpasses.
