Measurements on Ford shock mounts?
Discussion in 'The Garage' started by Sandman, Dec 23, 2002.
  1. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I've got the shock mounts and the Rancho 5012 shocks but the way my rig is right now (torn down), it would be hard to judge how high I should mount the shock mount on the frame. What has worked out for you? I have a 6" lift with a D60. Thanks.
  2. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    It's kind of hard to explain but you want it low as possible without your shock bottoming out when your tire is tucked. I also used the distance between the axle and bump stops. I have a 6" lift.
    few pics of mine
    http://www.off-road.com/chevy/tech/f250tower
    Are they still selling those?
  3. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    I had a hell of a time with mine, had to notch the firewall at the sterring column. but I only have a 2 1/2" lift and didn't want to bottom out the rancho 5012.
  4. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    How much of the shock tower do you have left? Thanks for the pics.
  5. Shawn
    1,753
    5
    5280'
    8.5" is the length of the shock tower but as you can see, I should made it longer so I could install a 3rd bolt at the bottom.
  6. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    So maybe 9.5"'s or so. How close is the shock to bottoming out when you tire is completely stuffed?
  7. Shawn
    1,753
    5
    5280'
    Maybe 10". You want it even with the bottom of the frame. If I had to do it over again, I'd adjust it to the shock first then cut it. I think I have 1/2" of shock left when the tire is stuffed.
  8. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Thanks. I'll go with that and hope for the best. I cant really set it up as a few other things are apart now also.
