measuring lift, rear blocks?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dasanii19, Apr 5, 2007.
  1. dasanii19
    dasanii19 1/2 ton status
    Oct 11, 2006
    344
    NV
    The block is slanted, so im thinking I measure from the long side to see how much of a lift I have, correct? Im measring 3 1/2" does this look and sound right to you?
  2. sweetk30
    Nov 1, 2004
    25,539
    539
    horseheads , ny 14845
    block for 4" lift. the rear blocks come in under sized to the frt springs. dont forget taper short to front of truck long to back of truck.
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Measure the block in the center, this is how much lift you will gain. The taper to the block is just going to rotate your pinion angle up (or down) depending on which way you install the block. The large part is what is supposed to go toward the back of the truck so it will point your pinion upward to help with pinion angle.
  4. thebird00
    thebird00 1/2 ton status
    Nov 8, 2006
    995
    Camden, NC
    I have this same question in the garage right now. It seems obvious to put the tall side to the back and the short to the front, but I always thought with a non cv driveshaft you want you driveshaft angle to match at the transcase and the diff. Installing it that way puts the u-joint at zero angle at the rear diff which I always thought caused vibrations and u-joint failure.
    Sorry not trying to steal the tread. But yeah measure from the center of the block for the amount of lift.
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    You're forgetting that when you lift the rig your driveline angle is changing and the taper block is there to help it. On short wheelbase vehicles it is very hard to get the working angles the same and keep the driveline angle correct at the same time. Either one being off can cause a vibe.
  6. thebird00
    Nov 8, 2006
    995
    Camden, NC
    Forgot to mention its on a 93 long bed dodge. With it in there as stated the driveshaft is at zero angle with the diff. with it flipped the diff is parallel with the transcase. superlift said to put it in like you stated. just wondering.
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If the long side is 3.5" the block is a 3" block, like I guessed from the pics that you showed me a while back.
    The middle is where you wanna measure and it will be 3" :D
  8. dasanii19
    Oct 11, 2006
    344
    NV
    haha yea I remember you telling me that awhile ago, your good!! I was meaning to ask you to keep an eye out for me if you would for some 3/4 ton axles. Id like to do the upgrade.
  9. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Did you see my post?
    I am selling a set.
  10. dasanii19
    Oct 11, 2006
    344
    NV
    I saw it after I replied. Didnt you sell one axle?
  11. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I have front 8 lug outers. :D
    I'll PM you and we'll talk.
