measurment on 14FF center pin to center pin?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ImpalaSS, Dec 1, 2001.
  1. ImpalaSS
    ImpalaSS 1/2 ton status
    Feb 1, 2001
    201
    if anyone can tell me what the measurement is on a 14 FF from center pin to center pin it would be greatly aprecited...
    trying to figure out what my axles from! so i need the measurment for a 3/4 14bFF and a 1 ton 14bFF
    also if anyone knows the measurment for a 67-72 12 bolt that would be great!
    thanks again
    68 SWB 4x4 1 of 1,449 made 327, 465 4 speed, rockwell tcase, dana44, 14 FF, <a target="_blank" href=http://communities.msn.com/68K10>http://communities.msn.com/68K10</a>
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    I just went out and measured mine and it looks to be 42 1/2
    That is on a 3/4 ton 14FF
    Middle of the hole to middle of the hole.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    You can use any 1 ton 14FF on your '69 without doing any relocations of the spring perches. The shock mounts would need to be relocated, though.
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  4. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    Good that yours is 42.5, cuz that is what is supposed to be.
    If you ain't hurt, you ain't playin' hard enough.
    The General
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Aren't the '67 to '72 trucks all the narrower perches? Like those on the 1 ton rears? Or are there some years you can use a 3/4 ton wider perch on?
    Personally, I have never messed with the '67 to '72 trucks. So, I'm just passing what I have heard. [​IMG]
  6. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    They are all narrow just like the 1 tons.
    See Ya,
    Keith
    <font color=green>Born to Drive My K5</font color=green>
    <a target="_blank" href=http://coloradok5.com/gallery/californiak5>CaliforniaK5's Pictures</a>
  7. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    68SWB,
    I was just taking a few measurements last night....! [​IMG]
    The 12-Bolt that I have under my '72 appears to be 40" (It's hard to get a perfectly straight measurement with the diff in the way....)
    The 14BFF sitting in the "on deck circle" measures what appears to be 42.5" like everyone else is saying.....even HARDER to get a straight measurement (bigger pumpkin!)
    Good thing I just bought a new die-grinder.....looks like I'll get to practice with it on the 14BFF.....cutting off the spring perches and shock mounts! [​IMG]
    -Greg72
    '72 K5 Blazer - 427BB/TH350/NP205/6" Lift/35x12.50's
    <font color=blue>See it here: </font color=blue><a target="_blank" href=http://coloradok5.com/gallery/albun38>http://coloradok5.com/gallery/albun38</a>
