mechanic in denver
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by ta70cst, Nov 29, 2001.
  1. ta70cst
    ta70cst Registered Member
    Nov 14, 2001
    28
    Colorado
    Does anyone out there know a good mechanic in Denver for my 70 blazer? I need some gaskets replaced to stop some oil leaks and do not have the time.
    Thanks in advance,
    Tom.
  2. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    I live East of Denver by Limon. What gaskets do you need replaced? Engine, Tranny , transfer, window, hood????????
    John
    Like to go sloppin' 'round in da mud in a rapid fashion....=)
    <a target="_blank" href=http://coloradok5.com/gallery/albun31?&page=1>See my pics here</a>
  3. ta70cst
    Nov 14, 2001
    28
    Colorado
    Valve cover gasket (drivers side) and an oil pan gasket.. possibly need new valve covers.... hopefully this makes sence. I am not a mechanic..
    Thanks,
  4. chevyracing
    Sep 8, 2001
    2,589
    Colorado
    pickup the gaskets and come on out. If you can't get the gaskets I can. That should only take a couple of hours. You buy the beer........ If you want the oil pan done you should do the rear main seal and timing cover seals as well.
    John
  5. Ryan B.
    Jul 18, 2001
    5,693
    CA
    To change the oil pan gasket on my '72 K/5 I had to unbolt the motor mounts, jack up and support the engine, and unbolt&amp; remove the engine crossmember to get the oil pan out. Quite a hassle.
    My 2 cents
  6. Rhody
    Rhody Registered Member
    Oct 8, 2001
    22
    Wallingford, WA
    I just dd mine. I had actually pulled the motor and put in all new gaskets along with degrease and give her a nice new coat of orange paint along with some clear coat to keep it neat. Probably the best time to do all of that and like they said. Do the REAR MAIN and look at the flywheel and clutch. Just my two pennies
    Little Rhody
  7. chevyracing
    Sep 8, 2001
    2,589
    Colorado
    I agree, the whole engine should be pulled and all new gaskets put in for as cheap as gaskets are. It is easy to do and doesn't take but a few hours to pull it, tear it down and put in new stuff and have it wheelin' again.
    John
