mechanical and vacuum advance ?'s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Jun 8, 2001.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    mechanical and vacuum advance ?\'s
    can anyone tell me what a good amout of vacuum advance to run is? i have an adjustable unit and would like to optimize it but i need something to start with. also, when working with different advance springs, should i stick with the medium ones or use heavier/lighter?
    Check out my 73 K5 http://members.theglobe.com/xnoahx/73k5.htm
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Re: mechanical and vacuum advance ?\'s
    It is hard to say. Start with the med springs and the vacume advance in about the middle of its adjustment. You want the advanve to come in as fast as possible without ping. The vacume advance is for under load so set this and test up a steep hill.
    '71 Blazer CST with alot of rust
