Mechanical Clutch
Discussion in 'The Garage' started by bigblzr, Apr 25, 2006.
  1. bigblzr
    bigblzr Registered Member
    Jan 30, 2006
    17
    Thunder Bay ONtario Canada
    recently i rolled the 1987 k5 of mine and destroyed it. i picked up a cab off a 1992 chevy k1500 and made a custom subframe to mount the cab to the blazer chassis. over the past weekend i converted the wiring harness over to the 92' style and was able to get it running again. Manual Tranny has also been on the agenda even before i rolled it. the is a k5 for sale right now with a std. in it but it does not have the hydraulic clutch. i want to know if any of the 1988-1998 c/k cabs ever came with a mech. linkage clutch. if not, what would be the best way to connect the pedal. the k5 is going for cheap so i'd really like to maek this work
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    there was only a hydraulic clutch in the newer trucks. if you really want it to work, get a hydro bellhousing and slave cylinder for a 85-87,91 truck/burb/k5 and use that with the hydro pedal and mastercylinder from a 88-98 trucks.
  3. bigblzr
    Jan 30, 2006
    17
    around here where i live, hydraulic bellhousings are extremely hard to find, but i have though of that, thanks
  4. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    I seem to always post this link....
    www.car-part.com
    seems that whenever I need something they always have it...
    just bought a 1996 passenger side power window switch unit... has the power window switch, power lock and the entire plastic piece they are mounted in.... $15 plus $15 shipping (ups is now charging $10 surcharge to residence!!!! :crazy: )
