Mechanical Clutch
Discussion in 'The Garage' started by petryshyn, May 10, 2006.
  1. petryshyn
    petryshyn 1/2 ton status
    Jun 6, 2004
    150
    Yorkton,Sk
    I am wondering on the mechanical clutch set up is there a plastic bushing for the adjustment arm, because my slack and not fully engaged clutch seems to be coming from slack in the adjustment arm were it sits on the pivital linkage part..
    Any help??
    Thanks.
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Here's a scan of the parts illustration. There's a metal bushing and some seals, and that z-bar should be greased every so often. Alot of people overlook it, the metal bushing wears (usally disenigrates and falls out) and you get lots of slop in your setup.
    Usally not enough, however, to make the clutch inoperable, mabey very difficult to operate.
  3. petryshyn
    Jun 6, 2004
    150
    Yorkton,Sk
    Thanks, well i guess its not inoperatble, but shifting is hard when the pedal is to the floor so I am assuming that its not engaging fully. (Could anyone verify this)
    Thanks. And thanks again for the picture ( I swear I had one but could not locate it :( )
