Mechanical Fuel Pump **Pump Replaced, Noise Getting Worse**
Discussion in 'The Garage' started by nemesis_pyros, Jul 7, 2006.
  1. nemesis_pyros
    nemesis_pyros 1/2 ton status
    Mar 24, 2004
    229
    Winnipeg, Manitoba
    My big block is sounding like it has a loose rocker but I double checked and adjusted all the rockers so its not that. What I was wondering is would a mechanical fuel pump thats on its last legs sound like a loose rocker arm. ever since this noise got worse the truck does kinda stumble on hard acceleration but other wise runs fairly well. Also if its improtant I put in a new cam but it was making this noise before.
  2. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    describe the sound in more detail. Is it a clacking, clanking, ticking?
    Is the sound intermitant or does it constantly do it? Any times worse than others?
  3. nemesis_pyros
    Mar 24, 2004
    229
    Winnipeg, Manitoba
    Sorry for the late reply been busy all weekend.
    I have replaced the fuel pump this weekend and there was no change in the sound but the truck does run better now, the stumble is gone and infact the truck runs awsome. But this noise is getting really loud and its starting to really bother me.
    The sound is more of a clacking. It almost completely goes away when its idling and its the worst when crusing at 2000 rpms. Its also gotten worse over the weekend, but in the begining it was only apparent after the motor warmed up.
  4. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    was the fuel pump push rod damaged in any way, did you notice when you changed the pump? That or have you check your valve lash? maybe it is a valve out of adjustment.
  5. nemesis_pyros
    Mar 24, 2004
    229
    Winnipeg, Manitoba
    Ya I made sure to inspect the fuel pump push rod and it looks in good shape. The new pump didn't make any difference regarding the noise.
    Yes I adjusted the Rockers 3 times and I'm pretty sure the noise is not coming from any of the valves.
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Does your oil smell fuelly? If the pump went bad they sometimes leak gas into your oil thinning it down and causing noise/bearing failure.
  7. ak bandit
    ak bandit 1/2 ton status
    Sep 10, 2004
    386
    Eagle River, Alaska
    To completely rule out the fuel pump and pushrod as the source of the noise, take the pushrod out so the pump is not pumping. The carburetor should have enough fuel in the bowl to run. Give it a few revs...
  8. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    It might sound stupid, but have you checked to see if you have any exhaust leaks?
  9. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    i was going to ask about the exhaust also. :D
  10. nemesis_pyros
    Mar 24, 2004
    229
    Winnipeg, Manitoba
    Hmmm Maybe I should check the exhaust again. I did tighten up some bolts and that got rid of them. It really sounds like something clacking, I've never heard an exhaust leak sound like this before. We did take a mechanics stethoscope and try to find the noise but with no luck.
    And to the other responses. No the oil is fine the pump wasn't leaking any fuel in the oil. Taking the fuel pump off and letting it run sounds like a good idea although I don't think it will run long enough.
  11. Chevy305
    Jan 23, 2006
    11,228
    485
    New Hampshire
    When it starts stalling out just spray that starting fluid stuff down the carb.
  12. scrappyk5
    Mar 17, 2002
    2,099
    virginia
    spraying starter fluid or pouring gas in the carb while trying to make it run or keep it running is not a good idea. i have seen a few carbs backfire with huge flames coming out the carb when they did this, which resulted in fires and lots of damage:eek1:.
    also , could your timing chain be slapping the cover when you rev it up ?
  13. 54inches
    54inches 1/2 ton status
    Feb 9, 2004
    1,535
    Houston, Texas
    How many miles on the engine?
    Could it possibly be a collapsed lifter? Flat cam lobe? Main bearing?
  14. nemesis_pyros
    Mar 24, 2004
    229
    Winnipeg, Manitoba
    Brand new cam and lifters, timing chain has less than 5k miles on it and was in great shape when we took out the old cam. I'm sure its not a main bearing going sounds more like valve train noise.
  15. mike n
    mike n 1/2 ton status
    Oct 9, 2003
    101
    New York
    Sure you got the right fuel pump?
    A smallblock pump will bolt up and work, but the arm is different and will leave a gap between it and the pushrod, resulting in a knocking noise. And, with the extra clearance between the pump arm and rod, the pump doesn't travel fully resulting in reduced pumping capacity, which can affect full throttle operation (read: the pump can't supply enough fuel when the secondaries open, the carb gets sucked dry and the engine stumbles)
    Fwiw the smallblock part # is 40987, and I've had more than one parts store tell me their catalog listed it for a BB also. It isn't the right pump for a BB, ime.
  16. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    sounds like a spun main bearing
  17. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    test...
    You could rig up a "gravity feed" fuel tank to run it longer than the carb bowl will allow...an old lawnmower gas tank works well--we used one at the boneyard to start carbed motors,we'd put it up on the cowl,higher than the carb..but it will run on whats left in the carb bowl for at least a minute or two,long enough to diagnose most noises..
    You could have a collapsed or cracked piston skirt,I've seen quite a few on BBC motors..or a rod bearing thats loose..they rattle the most at about 2500 rpms,and when you let off the gas suddenly,its a metallic rattling sound...main bearings are more of a "thud" under load,they dont usually make noise at idle unless they are really wiped out--and you'd see the drop in oil pressure,if you have a gauge....a collapsed lifter is a possibility too..
    Also mke sure the flexplate isn't cracked,and the torque converter bolts are tight...noises can "travel" and sound like they are in one place,but actually originate in another--a mechanics stethascope could be helpful in your diagnosis:crazy:
