Mechanical / hydro clutch pedal differences ????
Discussion in 'The Garage' started by tarussell, Dec 23, 2003.
  1. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I need some info on the differences between the older mechanical clutch pedal set up v/s the 1985 and up hydraulic pedal assy.
    Is there any part of each set up that is the same ?
    I have several mechanical pedal assy's but no hydro set up's and it looks like I will be needing to use the pedals of the hydro set up and I need to know what will and what won't fit .
    Just for the record - I am converting my 1986 K5 that came with a TH700R4 to a 4-speed and need to make a clean reliable pedal conversion.
    Any help/info or comments would be greatly appreciated !
    If anyone has PICTURES of a 1985 and up pedal assy I would really like to see them .
    Thanks in advance ! Tom
  2. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    TTT for a brotha. /forums/images/graemlins/thumb.gif Maybe the night crew will know... /forums/images/graemlins/thinking.gif
  3. dyeager535
    26,982
    191
    Sorry, nothing like that.
    diagram
    part numbers
    /forums/images/graemlins/smile.gif
    If you can find someone with an '84- parts manual, maybe they could cross reference the clutch pedal (pieces) part numbers for you.
  4. dyeager535
    26,982
    191
    diagram
    part numbers
  5. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    Thanks ..... I guess I am gonna have to spend some quality time digging through the books at my local GM dealer.
    I was hoping to see some pictures to compare the parts. I realize that I am asking for a rare and odd-ball components and on top of that I am hoping someone actually has a picture of those parts . /forums/images/graemlins/rotfl.gif
    If anyone has any info on the hydraulic stuff please feel free to share some wisdom !
    Thanks ! Tom
  6. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
  7. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Thanks!!
    Great Info!!
  8. Impex
    469
    Chandler, AZ
  9. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    COOL ! Thanks for the pic's !
    Just so you know - Your avatar brings tears to my eyes every time I see it - such a perfect example ....... /forums/images/graemlins/thumb.gif
  10. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    It has been a while since I did this but this is what I remember. I have a '77 (4 speed) and set it up for the hydro. You will need to swap buckets from a manual into your auto.
    The buckets where the pedals bolt to were the same as were the sleeve and bolt that the pedal pivot on. The pedals are different so I cut and welded one new and one old pedal to get mine to fit nicely. I think that the bushings were the same but the pedal stops and the return spring are different. All in all it is pretty staright forward.
    Mike
  11. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    Thanks to all who responed ! /forums/images/graemlins/thumb.gif
    This helps in giving me some direction for my hydraulic pedal project .
    Once again THANKS ! Tom
