Mechanical Temperature Gauge Questions???
Discussion in 'The Garage' started by RingMaster4x4, Jul 1, 2003.
  1. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Could the Tube that runs from the sending unit on the end to the gauge in side the cab gather heat for the engine compartment causing it to read wrong? /forums/images/graemlins/confused.gif /forums/images/graemlins/thinking.gif
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    It could, how far doe's it reach? And with tubing running any major length, it will dissipate heat out of the tube. /forums/images/graemlins/grin.gif
  3. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    well it runs about 3-4 feet right through the middle of the engine compartment about 6 inch above the engine.
  4. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
  5. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    I'm a dis-believer /forums/images/graemlins/smirk.gif My guess is most of the force to move the gauge comes from the larger sensor end of the capilary tube. I would think the (middle) tube temp wouldn't have too much effect unless it was laying across the exhaust manifold or something.
    Test it /forums/images/graemlins/smile.gif Lay an ice cube or heat gun to the tube and see if effects the reading to any degree. Tell us what ya got /forums/images/graemlins/ears.gif /forums/images/graemlins/thumb.gif
