Mechanical Tranny Temp Gauge In 700R
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dawson444, May 8, 2001.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    I got an autometer tranny temp gauge to put in my 700. I took it to the guy who rebuilt my 700 today to get him to do some things, as well as put in the sensor for the gauge. He said he didn't know if he would be able to find a place in the pan where the sensor could stick in enough w/o hitting anything. Anyone got any advise? Thanks!
    Dawson
    Raleigh, NC
    88 K5, 4" lift, 33" BFG muds
  2. Oblin Goblin
    Oblin Goblin 1/2 ton status
    Apr 30, 2000
    205
    Davis, CA
    I put a sender in the pan on mine and it did interfear with the shift linkage inside the pan. Didn't find out until the shop tried to put the pan back on. What they did was put an elbo pipe fitting in the pan, one that expanded so that it could screw into the pan and accept the sensor on the other end. My only concern is that it is hanging off the tranny quite a bit and the fluid in the elbo may be cooling down so that I'm not getting a good reading. I've heard that the best place for a sender is in the out line from the transmission to the cooler. You might want to try that if you can.
  3. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    I used an external engine oil filter in the output line of my TH400. This gives you a big fliter and the mounting head gives you a place to screw the temp sensor into. Summit sells these for about $20 and they will work on any auto trans. Just make sure that you use the four port design for the adapter. I bought mine for a chevy engine so that the trans and engine use the same filter. The hardest part was finding a good place to mount the filter. I put mine up near the radiator on the frame.
  4. dyeager535
    26,980
    If you can find an adapter, put the sender in one of the pressure test fitting ports on the side of the tranny. They will be plugged by a square headed bolt.
    Dorian
  5. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    I got the exact same guage for my 700. I haven't put it in yet but I got a T fitting, with a reducer on each end and I will some day put it in the line going to the cooler. It is kinda big and bulky but it was the only way I could think of doing it with out having to get really custom. I haven't put it in yet so I can't tell you how well it works but that was my idea. (Boy I hope it works) lol [​IMG] Hope this helps.
    Ben 87 Jimmy
    <A target="_blank" HREF=http://www.bens87toy.coloradok5.com>http://www.bens87toy.coloradok5.com</A>
  6. Itali83
    Feb 12, 2001
    795
    Westbrook Maine
    Ben 87 Jimmy
  7. dyeager535
    26,980
    Not talking about the cooling lines, I personally don't like the idea of cutting into them if I don't have to. (although my car has an aux. trans cooler in it) There are pressure test fittings on the side of the tranny. They are square plugs. All you'd have to do is get an adapter from those threads (if they are even different) to the sender threads, and screw it in.
    Dorian
  8. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    Where could I get an adapter for that? Thanks!
    Dawson
    Raleigh, NC
  9. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    I did this, but I used what was supposed to be an engine temp gauge. The only difference between them is the size of the sender. I already had a drain plug in the back of my transmission pan, so I enlarged that and mounted a fitting in the hole that would accept the sender. Now to drain the oil, I just remove the sender.
    There are three ways to measure the transmission temp.
    -pan
    -oil send
    -oil return
    The pan is generally considered to be the best all around measurement for safe operating temperature. Anywhere that the sender is dunked in pan oil is fine. The hottest measurement will be the oil send line, as that is oil coming directly out of the torque converter. It will be especially hot if you don't have a lock up converter. That is where most of the heat will come from. However, you can hit 250 degrees on that line without bringing the pan over 160 if you have a good cooler. Generally you just need the pan temperature. B&M recommends putting a line sender on the return line (cool) instead of the send line (hot). Personally, I run one in the pan and one on the send line. I plan to someday buy a seocond sender and put it on the return line so that I can use the same gauge for both, just by flipping a switch. That's part of the beauty of electrical gauges.
    Good luck with whatever you decide to do.
    <font color=green>"Do not replace belt while engine is running" --Warning on a Kelly Srpingfield package</font color=green>
  10. dyeager535
    26,980
    Any decent hardware store should have the adapters/reducers you need. Not one of those chain stores, but one of the ones where the employees actually know where everything is at!
    Dorian
