Mechanical vs. Electric Fuel Pumps
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Jan 7, 2002.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    OK, I think I may have just gone thru my second Summit electric fuel pump... [​IMG] Do I have to stay electric, or can I go mechanical to avoid this PAIN of replacing my fuel pump every other month?
    Why stay electric on a carb'd motor? The only thing I can think of is security... I run a hidden switch to kill the pump when I'm leaving the truck anywhere questionable. I could just as easily switch the coil + too...
    Thanks all... [​IMG]
    <font color=red>GOT MUD???</font color=red>
    My license plate reads:<font color=blue> 8 YR SUV</font color=blue>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s - 36" TSLs
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I say go mechanical and loose the headache.
    -- Mike
    <font color=blue> Married to a woman who understands the need for <font color=orange>Hugger Orange. [​IMG] <font color=blue>
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Since you don't have the stock '87FI motor in your beast, I'd go mechanical. Heck, I'd go mechanical if I could on my TPI motor [​IMG]...........
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com/>BlazzinOR's Home Page</a>
  4. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Then which mechanical pump to buy? I've looked at a few... Edelbrock and BG. Holley probably has one too. Anyone out there running any of these have nothing but good stories to tell? Or bad stories too for that matter [​IMG]!!!
  5. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Re: Mechanical vs. Electric Fuel Pumps *DELETED*
    Post deleted by KRAZIE87K5
  6. BurbinOR
    5,829
    Oregon
    I had a pretty rowdy 454 in the '75 Blazer I used to have, put an Advance Auto Parts pump in it and never had a problem in the two years I owned it............seems to me a mechanical fuel pump does not need to be a name brand. Unless you're revving that rat way high I'd check the difference in price between a name brand and a stocker and make the decision.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com/>BlazzinOR's Beast Buildup</a>
  7. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    That's a very good point... but I'm not sure that I can get a refund out of Summit for the pump I bought from them - so I might be stuck taking a Hi-Perf. brand name pump... which is just fine too. [​IMG] If I can refund, I will go that route!
    Just in case though, can anyone give any quick feedback on the three pumps I mentioned previously?
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    dont forget carter, run a return line type regulator
    formerly 77chev
    still a jerk though
  9. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    holley blue pumps work great. The first one I had lasted 3 years in the firebird. The only thing I had to do once in a while is pull the bottom cover off and clean it out since I run the original tank so its got a lot of crap in it :) Its easy to clean the veins out (4 bolts)and the gasket is reusable. DONT USE BG JUNK. everyone I know that uses barry grant has had nothing but problems and try to get rid of it fast.
    86Jimmy 4"&35"MTRs,87 burb 4"&33"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  10. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Well, I took out the electric and am returning it to Summit for a refund. I went to AutoZone and bought the mechanical pump and pushrod for $20. Installed it in 1hr in the 30* driveway, and she started right up! And as for the BG pumps, I was never into paying out $200+ for a elec. fuel pump.
    For the 454 I bought a pump for a '70 Chevelle w/a 454. It works with no issues.
    Thanks for everyone's replies! [​IMG]
