melted printed circuit
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Ressurection, Jul 1, 2002.
  1. Ressurection
    Ressurection 1/2 ton status
    May 9, 2000
    360
    Prairie du Sac, Wisconsin
    Has anyone had a melted printed circuit for the instrument panel? Would that be a voltage regulator? Is there a sure fire way to check systems before re-installing a new one to prevent this from happening again?
    Thanks!
  2. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    sounds like something shorted out and heat melted it.id check your wiring also before installing a new one.my truck also has wiring problems.the guy i bought the truck from liked to hack and splice all over.i had to run new wires under dash because i had a short.luckily the fuse blew before it had a chance to do more damage.
  3. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    Its a simple fix if it is one of the trace circuits on the board. I have fixed several with good results. If your not sure weather you have fixed the problem causing the short, make yourself a test wire with a light in fuse like 1 or 2 amp fuse. Scratch away the green coating covering the areas not burned on that circuit. You only need to do small spots on either side of the burnt and broken circuit.
    Once you have access to the metal trace, make sure it is getting power, and touch your little test wire to the bare spots. If the fuse holds, then your probrably okay. You can solder in some real light wire (like the a strand from a section of telephone line.) and only have to jump over the burnt section. This has worked for me many times.
