Memphrica
Discussion in 'The Garage' started by k5 beast, Mar 2, 2006.
  1. k5 beast
    k5 beast Registered Member
    Mar 21, 2005
    22
    memphis, tn.
    Well since I do live in what I percieve to be the worst city in the U.S., I'm installing a battery cut off switch and when I turned on the nut to take the positive wire off of the solenoid the damn thing went to pieces. So I took the starter off and tried to take the solenoid off and even after soaking in pblaster it still will not come off any suggestions, other than drilling and tapping. The starter is original more than likely as well as the solenoid and it's a 79 should I just replace them both?
  2. absolute
    absolute Registered Member
    Apr 7, 2005
    77
    Near Spokane, WA
    Why not... might even think about adding a ford solenoid mounted on the inner fender to keep it away from heat and dirt!
  3. k5 beast
    Mar 21, 2005
    22
    memphis, tn.
    Ford?
    What this about mounting a ford solenoid? What type would I ask for? I use the local Napa store for most things. Could I leave the current solenoid attached and use the existing starter then add the ford solenoid? Also with all the length of wire I've added I'm concerned about the voltage drop. Should this be a concern?
  4. absolute
    Apr 7, 2005
    77
    Near Spokane, WA
    just get a Ford solenoid for any pickup, mine is from a 88 F-250. Use 2ga wire and don't use the Neutral safety switch if you go the 88 route. If your going to put a new starter in any way it will work fine! Also do a thread search for "Ford Solenoid" or "Hot Starts"
