Messed up on gears!!!!!!!argueeeee
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by gokartergo, Mar 24, 2001.
  1. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Well I got a quote from a guy to redo my gears on my 10 bolts. $1150.00. I have 3.08's and wanted to go 4.56's. I was up at 4WPW buying some shocks last weekend. The guy gave me a killer deal on the ring-pinion. Normaly $139.95. He knocked them down to $99.00 each. The install kits are normally $49.00 He gave them to me for $29.00 each. And he only charged me $19.99 for each set of bearings. Well I got everything for just over $400.00. I was thinking I got a great deal. Then I went back to the guy that gave me the quote and asked him know how much he would charge me. He said nope. You didn't buy the gears from me so I won't do them. In this area I only found 2 other companys that would even do them. They both wanted $350.00 for the rear and $450.00 for the front. So know it would cost me more then if I would have had him do it in the first place. Well my brother is a mechanic. But he hasn't done any gears since he was in school. I talked him in to doing it with me. So we are both going to learn together how to replace gears.........And I thought I was getting a great deal. The only thing great about it is I am going to learn something.!!!!!!!
    Become one with nature..........Then marinate it..
  2. MudRebel350
    MudRebel350 1/2 ton status
    May 20, 2000
    324
    N.J.
    Like the saying goes "Live and Learn" thats ok at least you will feel like you accomplished something after its all done.
    JD
  3. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Holy cow! I had an Auburn limited slip put into my blazer and the guy charged me 70 bucks, I supplied everything else, the bearings , the lube, the seals, the Auburn. The gears came off the old carrier so whats the difference? Call the fire dept where you live, I did, these guys are mechanics and builders and carpenters. Hell they only work 10 days out of the month. My tranny guy is a fireman, he charged me 450 to rebuild my 700r4 and 50 to reseal my tcase. Worth a shot. Good luck
    creepin' and crawlin'
    Jim
  4. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Well I know it is kinda a P.I.T.A. If you can remove the axles from the rig and take them to the shop your price will drop. This of course means you will have no wheels for a bit but it will save you $$$$.
  5. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I think going from a 3.08 to a 4.56 would require a new diff. carrier. That may have something to do with the price difference.
    [​IMG] Semper Maintenance!
  6. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Do I need a new dif carrier?????????????
    Become one with nature..........Then marinate it....
  7. HispanicPanic
    HispanicPanic 1/2 ton status
    Mar 21, 2001
    351
    El Paso, Texas
    no only if you have a 12 bolt your 10 bolt does not change carriers and as far as the price the guys gave you they are way over priced i payed 350 for both front and rear with lockers front and rear here in el paso tx
    NOT ALL HISPANICS DRIVE LOW RIDERS :-)
  8. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    That is almost worth the drive there to get them changed........
  9. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Is there any special tricks to a 10 bolt. That would help me out????????
    Become one with nature............Then marinate it..
  10. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Something else you need to pay attention to in the future are what brands you buy. Not all ring and pinion sets are the same. Some "set up" fine and mesh well and others are just crap. For that price, it sounds like he gave you the crap ones. I heard Motive Gear is one of the worst. Richmond and U.S. Gear are my favs.
    '73 K5
    Chevy good...Ford bad
  11. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Why don't you buy the Richmond installation video, all the necessary tools, and then open a ring & pinion shop charging less than the other guys. I'm sure you'd make a lot of money.
    <font color=blue>//////
    <A target="_blank" HREF=http://blazer79.coloradok5.com>http://blazer79.coloradok5.com</A>
    </font color=blue>[​IMG]
  12. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Overall it isn't super hard, But I hate it... talk about a way to blow a day...checking clearences over and over is a huge pain. Hopefully if you keep track of the old shims and put them back in you should be pretty close
    1987 Chevy K5 Blazer- 350 TBI
  13. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    That is a good idea. I am going to buy the video. But no I am not going to open up a shop. I have enough headaches already........LOL
    Become one with nature.............Then marinate it..
  14. pr1aw
    pr1aw 1/2 ton status
    Sep 17, 2000
    144
    San Diego CA
    I miss 3RD member carriers.
  15. AMorris1
    AMorris1 Registered Member
    Mar 9, 2001
    8
    Fremont, CA
    I'm in the same situation. Bought my gears from 4WPW ... you know the story. Me and a friend are going to attempt to put them in this weekend. I think I have all the tools. There are serveral good articles on the web about it. Try differentials.com and ring-pinion.com. Will let you know how it goes
  16. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    How much does 4WPW want to install them? Seems they do a lot of gear installations here. Or did you mail order them?
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  17. OhioJimmy
    OhioJimmy Registered Member
    Jun 21, 2000
    92
    just moved to Kansas, Hoisington
    Man I hope you have alot of patience and a bearing press and a bearing puller, getting the crush sleeve crushed properly is very important. I bought all of my stuff from Randy'sring and pinion - ring-pinion.com and recieved quality parts "us gear" ring and pinion timken bearings and everything else hell of a deal. I got pissed putting mine together dues to lack of knowlege and lack of proper tools IE, bearing press and puller. So i took it to the gm dealer and had them install it for 260$ best money I spent all year. Good luck and inspect your carrier really close as mine was cracked and didn't notice it till the last minute.
  18. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I'm trying to buy the tape from richmond gears but can't find it.
  19. Blazer79
    1,816
    <A target="_blank" HREF=http://www.summitracing.com>http://www.summitracing.com</A> has it. Call them 1-800-230-3030
