Messy Oil Leak... I think?
Discussion in 'The Garage' started by eclipse, Jun 6, 2005.
  1. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    OK I'll try to make this short, last weekend I turned up my 85 k10's 350. New carb, plugs, wires, etc and an oil change. I had a slight drip from the oil pan before. Well I drove it friday morning, no problems, on my way home from work, something seemed odd and I popped the hood. There was fluild sprayed everywhere, the fan was wet so it had to have been flinging it. My first thought that it wasn't motor oil, but since I had just changed my oil it was clean. Well it seems like it must be coming out of the front of the engine, but I can find out where, it only does it when I am driving the truck and it makes a huge mess, and the front differentail is covered in oil also. The only thing I can think of is my timing chain cover. Any thoughts?
  2. dyeager535
    26,982
    191
    Have you tried operating the throttle by hand with it running and you watching?
    Could be a higher oil pressure thing, or coming out someplace that oil only reaches with it being whipped at higher RPM's.
    I "forgot" (wasn't my original block) to put a bolt in one of the holes on the front of the block near the fuel pump, and while it didn't leak while I was letting it idle, once I had it on the road for awhile, I had engine oil thrown over pretty much everything in the engine bay. I'm glad it was such an easy fix though! :)
  3. RustyParts
    RustyParts 1/2 ton status
    May 26, 2005
    235
    Wyman, Kentucky
    Could be a hairline crack in a power steering hose (if you have power steering) if not the front oil pan seal could be leaking onto the harmonic balancer and slinging oil.
  4. eclipse
    Jan 1, 2005
    1,245
    Sparks, NV
    thanks I'll have to check my power steering lines.
