metal in motor?
Discussion in 'The Garage' started by blazerboy72, Jul 21, 2002.
  1. blazerboy72
    blazerboy72 1/2 ton status
    Mar 29, 2002
    260
    hiram ga
    what do ya'll think is wrong it is 7.whatever a 454 in a 2000 dually 3500 THANX
  2. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    what exactly do u mean?? explain urself.
    NITRO
  3. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    uuhhhhhh what?more info and clear wording of what is wrong please?
  4. blazerboy72
    Mar 29, 2002
    260
    hiram ga
    i guess that was a little hard to understand let me try it again. my dad bought 2000 3500 truck. it has a 7.4(or whatever a 454 is) the other day he checked the oil and it had pieces of metal in it. he says it is either a main bearing or the cam i just seems a little early for that to happen since it is only a 2000 /forums/images/icons/confused.gif maybe that is a little better thanx
  5. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    metal in the motor is a bad thing. the metal itself can be very damaging, but whatever is causing the metal is probably a much bigger issue. Regardless of age, motors should never have metal in them, so yes it is too early for that to occur! you need to find out what is causing the metal. you could start by dropping the oil pan and seeing if there are any larger pieces in it. many things that break end up in the pan.
  6. chulisohombre
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    it is derinitely in your best interest to check the oilpan for any more debeis.does your dad have a warrantee seeing as this is almost a brand new truck.id have him call up the delership he bought it at and tell them what happened.he might even get a new engine out of it if they cant fix or find the problem /forums/images/icons/laugh.gif /forums/images/icons/laugh.gif
  7. jackedjimmy
    jackedjimmy 1/2 ton status
    May 18, 2002
    195
    Redmond WA
    if the truck is still under warranty, do not drop the pan.......it will most likely void the warranty. Bring it in and they should fnd out what's wrong and fix it free of charge.
  8. chulisohombre
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    thats a better idea if there is a warrantee.jackedjimmy is right on with that one.i wouldnt touch a thing.i wouldnt even start the engine anymore either.who knows what else will blow if it runs long enuf.blow a hole out the side of the block and take something else out.maybe you if it has enuf momentum.somebody once told me they saw a rod shoot out the hood of a car when he went to a drag racing event.not what i would want to happen if i was in the drivers seat.
  9. blazerboy72
    Mar 29, 2002
    260
    hiram ga
    the truck is just out of warranty /forums/images/icons/frown.gif has has asked several people and they all told him to keep driving it until someting changed they say it is either a cam or a rod bearing. the metal is the only sign of a promblem so nobody knows what it is. the oil pressure is still good and it runs great. we had it up to 95 yesterday and it is running great. he said he would take the oil pan off but he would have to pull the motor. i knew he should have kept the other blazer
