metal vent tubes on the 14ff and 60 housing
Discussion in 'The Garage' started by surpip, Aug 5, 2004.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    do i have anny other options besides tapping for threads? ideas thoughts? i need some options thanks alot,
    dale
  2. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    You can get fittings that are designed to go though bulkheads. Same type scenario but I don't know now thick wall they can go through or if they can work well with the curves of the housing. You could also get a weld on bung that has pipe threads in it. Or one last option is have the machine shop machine you a barb fitting out of steel with no threads drill the hole to fit that and weld it in.
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    alright cool, thanks, im looking for the cheapest and quickest option, i want to go out and wheel, that is the only thing holding me back /forums/images/graemlins/waytogo.gif
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Just go out and buy a 1/8" NPT tap. It should fit into the hole that the stock breather was pressed into without having to drill it out more. Then just pick up a 1/8" NPT x barb fitting and hook it up to your vent line (and run the vent line as high as you can and stick one of those cheep $.99 fuel filters on the end). To keep the shavings from tapping just put some grease on the tap.
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    alright ill do that. the main thing i was worried about was the metal in the diff housing, diddent like that idea to much, where can i find the npt fitting at? home depot? autoparts store? thanks alot,
    dale
  6. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Both, but your autoparts house is the best bet /forums/images/graemlins/thumb.gif
  7. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    duct tape for a trip or 2? /forums/images/graemlins/dunno.gif
  8. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Coat the tap with heavy grease. That should hold the chips & keep them from getting into the diff.
  9. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    sweet thanks alot guys!! the day is coming soon /forums/images/graemlins/peace.gif
  10. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I got the tap and brass fitting at Home Depot. Most auto parts stores around here sell more of those little minibikes then they do auto parts /forums/images/graemlins/screwy.gif
  11. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    ya no kidding i walk in in my typical shorts and sandals and automatically i dont know [darn], it really pisses me off. Yesterday the guy at car quest was like"you know, the GM 1 ton axel never came with disk brakes in those years", im like ya thats why its called a conversion, /forums/images/graemlins/angryfire.gif dick
