Metal windage sheild rivited on bottom of 350 factory aluminum manifold
Discussion in 'The Garage' started by lukebaby1, Jan 10, 2004.
  1. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    Is this sheild important? What function or advantange does it provide if any? /forums/images/graemlins/confused.gif
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    it helps to warm up center of intake to make cold starts easier and to help prevent icing, most of the time they are full of burnt oil, carbon
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    so can it be taken off and left off or not??
  4. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    It's done to keep oil off the bottom of the intake. The exhaust crossover is really good at cooking oil.
    Intakes without the exhaust crossover often have a really big one and that's done to keep hot oil off the intake and keep the water that passes through the intake from heating the oil.
    Some <crazy> people take these off and put magnets behind them to keep grenaded valvetrain from ending up in the crank. I think putting screens in the valley is good enough.
  5. lukebaby1
    Dec 16, 2003
    231
    Richmond, Virginia
    OK, so what are the problems I will have if I leave it off? /forums/images/graemlins/grin.gif
  6. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    i'm not certain about if they're available for Chevy, but i used to run aftermarket upper windage trays on my s.b mopars. that would take care of those issues probably. they didn't attach to the intake at all. layed in the valley with 2 bars that hooked under the edge of the heads.
  7. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    They have those available for SB and BB Chevy's as well. Have one on my 468. The factory pan helps prevent the oil from splashing on the crossover, although it doesn't stop all of it. Wish I had a dollar for every one that I have chisseled the carbon from there. /forums/images/graemlins/grin.gif /forums/images/graemlins/thinking.gif
