Metallurgy Question - I went to pick up some steel and was asked
Discussion in 'The Garage' started by 87GMCJimmy, Oct 10, 2002.
  1. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    Phoenix, AZ
    do I want hot rolled or cold rolled steel. Um.....duno! What's the difference, when would you use one instead of the other? What is the difference in price? Are there different welding techniques for each? I'm new at fabrication, I have had a welder for only a couple of months now, and need to learn the lingo. /forums/images/graemlins/1zhelp.gif
  2. tRustyK5
    Jul 23, 2000
    E-town baby!
    Well both are still mild steel so there is no difference in how they are welded.
    The hot rolled is obviously drawn hot and then quenched, easy to spot because the true dimensions are never dead accurate. A 3" wide flat bar is usually 2 15/16" or even less. It would also have 'mill scale'.
    Cold rolled or cold drawn steel is obviously done cold. No mill scale and it is very true dimensionally. Edges are sharp too not rounded off like the hot rolled stuff.
    Unless you need the material to be dimensionally perfect hot rolled is a better value. Most cold rolled materials I've used have been solid round stock or flat bar. I've seen and used cold drawn tubing but it's pretty spendy.
