Metalwork ruining my eyeglasses?
Discussion in 'The Lounge' started by Mastiff, May 8, 2005.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I recently got a MIG welder and I've been doing some body work on my pickup. Since my welding still stinks, much grinding is involved. ;) I always wear those high school chemistry looking goggles when grinding, and a full face welding mask when welding, but every day I seem to have more pits and burned spots on my eyeglasses. Last night I got a pretty huge burned spot.
    So... is this normal or something? Glasses are kind of expensive. I'm not too stressed right now since I need to replace these anyway, but I don't want this to continue. I'm not sure if grinding bits are getting around the goggles, or if it's mostly sparks from welding coming in from behind when I'm looking down welding. If it's the first thing, maybe I need better goggles or something? I'm not sure what to do about the second option... maybe glass lenses instead of plastic?
    Thoughts?
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Glass lenses are better at resisting pits & what-not from grinding and welding, but they will still get them.
  3. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    I wear contacts when welding and grinding have not hurt them yet. :D
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    My glasses last about 2 years before I need new lenses from too many pits and stuff.
    I wear them every day at work, but try and use the full face sheild when grinding. Fortunately my wife is an optical lab tech, so when I do need new glasses she'll either get me new lenses (of my choice) for nothing...or new frame and leses for cost. The most I've paid for new glasses was $65, and those frames retailed at $400.
    Rene
  5. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    I trashed mine too...
    I trashed several pairs of glasses too,the oxyacetalyne torch is the worst offender,I often use mine to braze metal patches on rotted areas and every time it spatters or pops when rust gets heated up, the tiny balls of metal get imbedded in the glass or plastic lenses--I'm wearing glass ones right now that look like a rock pucked windshield on an old car!--the plastic lenses really suck,they get damaged much easier than glass,but the glass ones aren't that much better either.
    ..I hate wearing glasses,especially now that my eyes are getting older,and I have to take them off every 2 seconds to read or look at things close up(I'm ready for Bi-focals I guess :mad: )--my eyesight is going downhill fast lately--I'm having a hard time seeing small things like the linkages on my lawnmower carbs and stuff--and I've resorted to using a magnifying glass to read code numbers--so I guess I have oficially become my father!....I try to remember to use a sheild or goggles,but usually dont until I get another chip in a lens,or worse,a peice of metal in my eye.. :blush: :(
  6. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Wow that's lucky!
    I wear both glasses and contacts when welding/grinding. Depends what I have on before I come outside. Usually if I am grinding I wear a face sheild with glasses, so I don't have any pits in my glasses...then with contacts I use saftey glasses...
    Maybe I am just lucky, or don't weld/grind as often...but my lenses are clear as glass.
  7. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Hmm. Something must just be weird with me. I always wear goggles or a welding mask. All I can figure is that when I'm looking down on the work, sometimes sparks fly up and fall back in from behind. The burned spots are on the inside of the lenses, so it's not like I'm getting a direct hit from the front.
  8. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    [HiJack]
    If cost is $65, and retail is $400 for frames, then that means the optical store really rapes the consumer. Thanks makes me feel better about dealing with them. I wear contacts, but I'm sure they're raping me too.
    [/HiJack]
    :xmas:
